Old 01-17-2014, 10:49 AM
MartySantic's Avatar
MartySantic MartySantic is offline
Same here with the milkhouse heater I used to use before the Reiff. When the fan motor was cold, the fan motor sometimes would not spin the fan blade.
Also, if you must use a milkhouse heater, elevate it by placing on a stool or something. Do not place the milkhouse heater under the plane. Had a hangar fire at KDVN that destroyed the plane. Theory was gas was dripping into the ducting.
Marty Santic ----- W9EAA
RV-12 N128MS ----- Now Flying
My RV-12 Build Log - http://www.martysrv12.blogspot.com/
Davenport, IA
Old 01-17-2014, 07:55 PM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
Installed the Reiff Rotax system during the condition inspection last month. Very effective. Flew on a 30 F deg day, oil temp at startup read 94 deg F. Only needed 5 minutes or so of warmup compared to the 15+ minutes usually needed without the preheat at that OAT.
Plan on getting the cell remote switch they offer. I drape a blanket over the cowl and plug the air intake holes.
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 260 Hrs on the Hobbs
http://unicom12.blogspot.com/
Click on above for build site
Old 09-07-2017, 02:12 PM
Piper J3 Piper J3 is online now
Default What Size (W x L) Pad Heaters?
I want to add two low-wattage silicone heater pads on my 12 to preheat both the engine crankcase and oil tank. I will use a cell phone switch to turn on the heat a couple of hours prior to flight. Question – does anyone know what size pad (L x W) will fit nicely on the bottom geometry of the 912 crankcase? Also, what size pad (L x W) that will partially wrap around the oil tank?
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 350
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 09-07-2017, 02:40 PM
JBPILOT JBPILOT is offline
Default Jim - -
I would highly recommend the REIFF pre-heat for the 912 engine. It has an FAA approved number on it. Works very good. You need to warm the oil tank also. If not, you will be feeding in cold oil the second it starts. You will burn more gas waiting for the oil in the tank to warm. Also, if you don't have it already, install the Thermostasis oil therm. Speeds up ready to fly oil temps much quicker. I feel they both pay for themselves in time.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-4-18 )
Old 09-07-2017, 07:56 PM
KALEWIS's Avatar
I want to add two low-wattage silicone heater pads on my 12 to preheat both the engine crankcase and oil tank. I will use a cell phone switch to turn on the heat a couple of hours prior to flight. Question does anyone know what size pad (L x W) will fit nicely on the bottom geometry of the 912 crankcase? Also, what size pad (L x W) that will partially wrap around the oil tank?
I 2nd the reiff system for the rotax. No measuring or cutting, it's ready to install and simple at that.
2 hours is not long enough with any preheat system like reiff or tanis. In cold temps below 40f I turn it on at least 12hrs before flight. Reiff has a thermostat that shuts off at 150f. I've never seen oil temps above 110 on the skyview before starting with the system plugged in overnight.
RV-12 #328
Old 09-08-2017, 06:24 AM
PilotBrent PilotBrent is offline
Installed EZ Heat system several years ago and it works great (when I remember to put the timer on and run it for several hours). One pad on lower half of oil tank, other one on bottom of block (pad fits fine on Rotax per your question if you are using the EZ Heat pads in your picture). On coldest days I will also place hair dryer on left cowl air intake when arriving at hanger which adds a little more warmth to the top of the engine via the shroud.
FYI for EZ Heat - Recall that I contacted the manufacturer to source one that had detachable electrical plugs on the pads to make removing the oil tank easier. Answer - for safety regs they did not offer that. So I just installed my own. I don't physically remove the tank from the engine very often (use drain plug), but if you don't made that mod, the power wires are fairly short making occasional Rotax oil tank cleaning more awkward to complete.
Brent Connelly
Hackettstown, NJ
RV-12, N913BC
http://www.mykitlog.com/brent45
Check out & subscribe to my Youtube channel for latest RV-12 flying videos...
https://www.youtube.com/channel/UCxQ...Px2I7jmazGdLqg
Old 09-08-2017, 08:55 AM
DHeal DHeal is online now
I also installed the EZ-Heat system (pictured above) in my RV-12 three years ago. It is inexpensive, easy-to-install, and works well. Granted I live in relatively balmy northern California (winter lows @ 30 degrees F). I typically use a timer to provide about 2-3 hours of pre-heating and all is toasty and ready to go. I also place an 18" Golden Rod dehumidifier tube in the cockpit during the winter to keep the cockpit warm and drive out moisture -- not really sure as to its effect, but it is easy to do.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 640+ hours (as of June 2018)!
VAF donation through June 2019.
Old 09-09-2017, 05:59 AM
Anyone have a picture of how the EZ Pad is mounted to the RV-12 oil tank? Is the pad flexible and allows curvature to conform to the tank? I'm leaning toward EZ Pad installation with cell phone remote switch/timer.
Thanks in advance...
Hinckley, Ohio
Old 09-09-2017, 09:18 AM
I have no pictures, but one pad gets easily glued onto the exposed lower front portion of the oil tank. The pad is sufficiently flexible to match the curvature of the tank. The second pad gets glued to a flat portion of the bottom of the crankcase. The "glue" they provide has worked well for me over the past 530+ hours.
Old 09-21-2017, 01:11 AM
I have installed the E-Z Heat preheater for the 912. Nice clean installation.
Next is to turn heater on/off with remote cell phone switch. I ordered this unit from eBay for $30 including shipping... https://www.youtube.com/watch?v=vYzthAVYBCk
Hinckley, Ohio
