Old 10-14-2009, 08:48 AM
F1Boss's Avatar
F1Boss F1Boss is offline
Default PM sent
Originally Posted by scsmith View Post
Wow, Mark, that looks like a much better quadrant than even the 'delux' one. The delux one from Vans still isn't stiff enough, too much rubbing stick-tion where the levers come through the guide. And for some reason, the friction adjustment won't make all the levers have the same resistance.
So, if it would fit in as a retrofit, I would be interested in one of yours,
Steve.
PM sent. Of course, anything can be retrofit with enough labor and $$$! The #10 c/s attach fastener pattern is ~2 9/16" W x 2 11/16" H
$265 ea.
Our lever guides are delrin; the levers are SS; the friction lock is a SS spring. Very smooth action, the friction setting STAYS SET; and it won't corrode when used in formation (sweaty hands, ya know). I put a dab of light machine oil on the throttle lever (just a bit less friction) so formation work is easier.
Carry on!
PS Smokey's setup (single lever + 2 verniers) is a good one too, esp for fine mix adjustments -- BTW didja notice those rear rudder pedals? That's using your head for more than a hat-rack!
Old 10-17-2009, 07:32 AM
N8RV's Avatar
N8RV N8RV is offline
Here's a better picture of the throttle in N8RV. Since I had to lower the mounting to accomodate the size of the throttle lever, I had a row of rivets to cover ...
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
Old 10-17-2009, 11:43 AM
flyeyes's Avatar
flyeyes flyeyes is offline
I can toss in a thumbs up for Mark's throttle quadrant--I have one in my -8 and it is one of the things I would do again in a heartbeat. It looks good and works very smoothly.
James Freeman
RV-8 flying
Old 10-18-2009, 04:11 AM
rv8ch rv8ch is offline
Default Delrin guides
Originally Posted by F1Boss View Post
Our lever guides are delrin; ...
That's sweet. I was thinking of retrofitting delrin guides onto the Van's deluxe unit, but since you've already done it...
Mickey Coggins
http://rv8.ch
Old 01-21-2011, 07:29 PM
Rocketeer Rocketeer is offline
I produce a nice repro version of the WW2 style -- actuator movement specs are set up for the normal air,fuel & gov requirements on our planes.
http://img86.imageshack.us/img86/803/quadrant.jpg
http://img198.imageshack.us/img198/9342/quadrant2.jpg
Carry on!
Mark- How wide (thick) is the unit? What is the current price? Are they on your website?
Old 01-22-2011, 10:33 AM
mike newall's Avatar
Mark,
Why did you put the levers in that order ?
Normally, the prop sits next to the throttle and the mixture is furthest away.
Looks a very nice unit - may yet be tempted.......
Old 01-22-2011, 03:47 PM
Adam Wright's Avatar
Adam Wright Adam Wright is offline
Originally Posted by mike newall View Post
Mark,
I don't see a reason why the balls for mixture and prop couldn't be easily swapped putting the mixture on the outside.
Old 01-24-2011, 09:09 AM
F1Boss's Avatar
1 7/8" wide; you can order direct thru my email:
f1boss (at) gmail dot com.
Carry on!
PS the shots with the knobs misplaced are in error - the knobs are placed correctly. I sent one to Fatboy for test fitting of his throttle lever knob - have not heard if it fits or not. I hope it does!
Carry on!
Old 01-28-2011, 09:48 PM
fatboy's Avatar
fatboy fatboy is offline
Default FatBoy meets F1Boss
Hey guys,
I've talked Mark into letting me sell his quadrants. They are soooooper smooooth, to say the least. No sticking whatsoever, and same pressure throughout the travel range. All 3 levers are identical in sensitivity. Drive down the tension nut where you want and throw your tension knob out the window. Mark testifies that no amount of vibration is causing slippage.
See my site for details -- I take the FatBoy grip, rework his throttle lever, and voila, you have the "FatBoss1". Keep going through Mark of course if you don't want the throttle grip on steroids, switches and all that, but I have to say, this is a quality product for sure. More pics/info at my site:
http://www.fatboythrottles.com
Flyeyes -- Just wondering how you mounted this in your 8? I'll post notes and other folks' install stories for reference on the site. Doesn't look too difficult, as it drops in clean, just need to tweak the attach hole placement a little.
Take care all -- Andy
Old 01-28-2011, 10:59 PM
flyeyes's Avatar
Originally Posted by fatboy View Post
(snip)
Mine isn't standard, as I have relatively short arms, and don't like the stock throttle position. Mine is moved back and inboard a bit, and I would do it exactly the same way again.
here and
here
I'm very interested in your grip--would it be a drop-in replacement for my current throttle lever?
James Freeman
RV-8 flying
