Old 10-13-2009, 06:43 AM
N8RV's Avatar
N8RV N8RV is offline
Originally Posted by Shockwave View Post
Don,
Where can I get one? I have a toy one for my computer, but I'd rather keep it for flight simming.
I found it on eBay many years ago. I haven't seen one recently though. I have a spare, but have promised it to someone else. If he changes his mind, I'll post it in the VAF classifieds.
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
Old 10-13-2009, 11:40 AM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Default Infinity?
Infinity was working on developing this but I don't know where he is with it. Or if it will ever be.
By veetail88
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 10-13-2009, 12:14 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Infinity has been "Workign on that" since before the Val's first flight over four years ago.....makes me wonder how hard they are working!
Don - if you excess your extra, let me know - that would look pretty cool in the -3!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-13-2009, 12:31 PM
scsmith scsmith is offline
Default Will Marks F1 quadrant mount with the same screw pattern?
Wow, Mark, that looks like a much better quadrant than even the 'delux' one. The delux one from Vans still isn't stiff enough, too much rubbing stick-tion where the levers come through the guide. And for some reason, the friction adjustment won't make all the levers have the same resistance.
So, if it would fit in as a retrofit, I would be interested in one of yours,
Steve.
Originally Posted by F1Boss View Post
I produce a nice repro version of the WW2 style -- actuator movement specs are set up for the normal air,fuel & gov requirements on our planes.
http://img86.imageshack.us/img86/803/quadrant.jpg
http://img198.imageshack.us/img198/9342/quadrant2.jpg
Carry on!
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 470 in 8 years
also LS-6-15/18 sailplane
VAF donation Dec 2017
Old 10-13-2009, 01:22 PM
xavierm xavierm is offline
Default Thrustmaster HOTAS Cougar
Originally Posted by N8RV View Post
For those interested, it's a Thrustmaster HOTAS Cougar. Amazon has them for $190. Can be found on eBay too. They are well constructed aluminum. I have the stick and throttle tucked away, planning on using them the same way.
_____________
Xavier
RV-7 build in progress
www.theaviatorx.com
"Genius is persistence in disguise"
thilokind thilokind is offline
Hi folks,
does somebody has some experience with the Andair throttle quadrant in an RV8?
Cheers
Thilo
Old 10-13-2009, 02:47 PM
N8RV's Avatar
Nope. Sorry, you lose.
It's not a Thrustmaster Cougar. This is the real thing. F-16 throttle control unit.
However, depending on how sturdy the Thrustmaster unit is, it may work just dandy. The only button that I connected from this is the SPD BRK button -- I use it to actuate my flaps. I had enough buttons on the matching stick grip to run everything else that I wanted to control.
Don McNamara
Peoria, AZ
Old 10-13-2009, 04:19 PM
N941WR's Avatar
N941WR N941WR is offline
FYI - A good friend was watching his grandson play some fighter plane game on his PC when he realized the would never press the buttons that many times in the life of his plane. So, he bought a Microsoft joy stick took it apart, ran the wires out the end and then filled it with epoxy and micro balloons to hold a threaded rod end in it. He then mounted that in his Velocity. He was right, the joy stick and Velocity out lived him.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-13-2009, 05:39 PM
Default Identical
the real thing is much cooler
I'll post pics of the thrustmaster when I get home.
_____________
Xavier
www.theaviatorx.com
Old 10-14-2009, 07:45 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Default Try this:
Ron Schreck
IAC Director and Regional Judge
Redline Airshows Pilot
RV-8, "Miss Izzy", 2100+ RV Hours
Track Me
VAF 2018 Donor
"He who demands everything that his aircraft can give him is a pilot; he that demands one iota more is a fool."
