Old 09-13-2017, 12:25 PM
Bluelabel's Avatar
Bluelabel Bluelabel is offline
Default Baffles Seals REV 2
I decided since the taxiway in front of my hangar was getting repaired for a couple weeks, I'd take the opportunity to re-do my baffle seals. My engine has always been on the hot side. Manageable, but I'd really like to have more headroom on hot days.
I though there was a pretty good chance I was getting some leaks in the back corners as the the air may have pushed the material down. We started with the original material from Van's.
I shopped a few things at Oshkosh and decided to give the McFarlan Cowl Saver stuff a try. It's extremely slick on one side and much stiffer than the original.
While I was at it, I figured I'd make it look cool too. Worst case scenario, I have the same cooling and a better look with the cowl off.
So, I whipped up new strips for both sides so the rivets had something good to bite into, off to the anodizer, and here we are.
First flight with them was on Saturday to fly young eagles. Getting the cowl on for the first time was a bear!!.
So far it seems I may have lowered the temps a couple degrees at best. Won't really know for sure until I go somewhere where I can get up high in cruise where I know exactly what temps I usually see.
Here's the before and after pics...
Before:
After
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Lead on the
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system
"so I got that going for me... which is nice."
2017 Dues Paid"
Old 09-13-2017, 12:54 PM
rv8ch rv8ch is offline
Default Cowling inlets
Hi John - thanks for sharing the photos - do you have any pic of the area around the cowl inlets? That's always a tricky area I believe.
Mickey Coggins
http://rv8.ch
Old 09-13-2017, 12:58 PM
Bluelabel's Avatar
Those are the only pics I took. everything there is to see is there.
John Walker
RV-10 N265WD
KEOS, Neosho, MO
Crew Lead on the
twin turbo, IO-540,
2017 Dues Paid"
Old 09-13-2017, 04:23 PM
Default Baffles
John, what did you do to finish the baffles? Paint, powder coat, anodize?
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 09-13-2017, 06:29 PM
Bluelabel's Avatar
Just high temp paint. I anodized the strips for the baffle seals.
John Walker
RV-10 N265WD
KEOS, Neosho, MO
Crew Lead on the
twin turbo, IO-540,
2017 Dues Paid"
Old 09-13-2017, 06:40 PM
krwalsh krwalsh is offline
Default Umm..
Excuse me for a few weeks. I'll be in the hangar redoing my baffles. They suddenly look awful...
Nice work there. Can I ask what the insulation on the wiring (?) is for?
Kevin R. Walsh
Cozy Mk-IV
Old 09-13-2017, 07:00 PM
Bluelabel's Avatar
Thanks....Just heat shield. To protect everything as best we could. Inside, anything that's a signal wire is shielded from other signal wires as well.
John Walker
RV-10 N265WD
KEOS, Neosho, MO
Crew Lead on the
twin turbo, IO-540,
2017 Dues Paid"
Old 09-13-2017, 10:01 PM
DanH's Avatar
DanH DanH is offline
Originally Posted by Bluelabel View Post
Those are the only pics I took. everything there is to see is there clear as day
So, John, do you have seals around the inlets? I think I see rub marks on the baffle tin, but your answer suggests there are none.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-14-2017, 10:13 AM
Bluelabel's Avatar
Yes, I have baffle seal material on the sides of the ramps. Same thing I've seen most other people do. That area gets a great seal.
I don't have any pictures of that. I might redo it with the new material so it's consistent.
John Walker
RV-10 N265WD
KEOS, Neosho, MO
Crew Lead on the
twin turbo, IO-540,
2017 Dues Paid"
Old 09-14-2017, 02:22 PM
AviatorJ AviatorJ is offline
John, what's on your firewall?
Justin
RV-10 Quickbuild 'Avionics and Interior'
http://operationrv10.blogspot.com/
Donated for 2018
