Old 09-13-2017, 12:54 PM
backcountry backcountry is offline
Default Brakes
I find it difficult to taxi in a crosswind and it doesn't take a lot wind to go passed the capability of the brake.
Question: is there larger brakes available for the RV-12?
Old 09-13-2017, 01:08 PM
Default Not sure--
if Beringer is making a caliper package for the 12. Retrofitting their calipers will require some work. Groves might convert, more easily.
Is the issue more holding power?
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 09-13-2017, 01:25 PM
The steering friction on your castering nose wheel may be set too light. I experience the same symptom when taxiing in cross wind.
You get used to dragging a little bit of brake...
Hinckley, Ohio
P/ASEL 1970 Sport Pilot since '04
RV-12 E-LSA #120058 AWC 7/12 Bought Flying 10/15 with 48TT - Hobbs now 317
LSRM-A Certificate 2016
Old 09-13-2017, 03:02 PM
Yes holding power is the problem. It will weather vane and not enough rudder & brake to hold it.
Old 09-13-2017, 03:09 PM
Raymo's Avatar
Raymo Raymo is offline
I too would suspect the nose-wheel breakout force is not sufficient. My -7A handles most mild wind with rudder only once moving.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 09-13-2017, 09:10 PM
How much wind are you talking about? I've never had an issue maintaining directional control, but I have had to repeatedly tap a brake to stay on center line with 10 knots crosswind on a taxi way.
Old 09-14-2017, 04:49 PM
It can handle more right x-wind but a 10 knots left X-wind for me is difficult and much more than tapping. Very heavy braking. I've flown with another RV-12 and it had a difficult time. I've flown many aircraft and started instructing back in the 60's. I'd like to have more brake to feel safe.
