Old 09-13-2017, 09:17 AM
rleffler's Avatar
rleffler rleffler is offline
My last two sets of Rapco pads looked like that and wore pre-maturely. I bought both sets at the same time. I suspect that there was a batch issue. After the first set, I paid attention to ensure that I wasn't riding the brakes.
After a couple incidents where the brakes faded when I attempted to stop, I upgraded to Matco brakes. With double the brake pad area, I now have no problems stopping as quick as I want. Only time will tell how these pads wear compared to the Rapcos.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 09-13-2017, 10:39 AM
rvdave rvdave is offline
Bob do you have the stock Cleveland wheels/brakes?
Dave Ford
Cadillac, Mi
Old 09-13-2017, 12:03 PM
rleffler's Avatar
The RAPCOs were on Cleveland wheels. When you upgrade to Matco, you must use Matco wheels and brakes.
Bob Leffler
Old 09-13-2017, 07:11 PM
Ivan Kristensen's Avatar
Ivan Kristensen Ivan Kristensen is offline
Default Matco upgrade?
Bob, could you give a little more detail on this upgrade? Part numbers and cost would be helpful and also installation difficulties if any? Thx.
RV-10 Quick Build
SN # 40838 (C-GMDV)
First flight June 28, 2010. Now 1035 hours of flight time.
Home field is Waterloo Regional Airport (CYKF) Ontario Canada,
2018 VAF dues paid.
Link to my build site:
https://ivankristensen.smugmug.com/B...ENTAL-aircraft
Old 09-13-2017, 08:39 PM
Default Matco
I purchased the matco package and I think it was about $1200 a couple years ago...very nice.
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 09-14-2017, 07:13 AM
rleffler's Avatar
matcomfg.com
There is a box on the front page for the RV-10 wheels and brakes. If you have any questions, give them a call. George is more than willing to talk with folks and explain their offerings. Do allow some time to get them. They are built to order. It took about a month to get mine.
I don't recall the exact price, but I believe they were around $900 for the pair. Of course, since I upgraded during my condition inspection and my four year old tires were shot, so I also bought new tires and tubes. This bumped the total cost to about $1,500.
They are no big deal to install. You will have to drill new cotter pin holes in the axle. Also, I would purchase one size longer bolts than they specify in the manual. You also need to purchase their spacers, which are on their site, but they don't highlight that very well.
Your wheel pants will get shifted inward about 1/8" to clear the brake AN fitting. They do supply these washers. Otherwise you have to modify the wheel fairing bracket. I went with the washers.
BTW, Geoff installed them several years ago too.
I can tell you that they are much more effective than the Cleveland brakes.
Bob Leffler
Old 10-10-2017, 12:58 PM
Originally Posted by vetterman View Post
Those look typical of rapco pads. We quit using them a few years ago as they didn't last very long. We switched to APS front aero in stock. They are made of a different material and last 3-4 times longer. I also talked to George at Matco at Oshkosh and the matco pads look similiar to the APS pads. Next time I need a set I'm gonna order them from Matco and give them a try. Larry v.
Is there a part number for aps pads to replace the rapco?
Dave Ford
Cadillac, Mi
Old 10-10-2017, 06:21 PM
vetterman vetterman is offline
Default Brake pads
I'm sure I just told the sales guy in need 66-106 and he knew the APS number. Btw I've been using the APS and they wear 10 times better than the rapco.
Old 10-10-2017, 07:11 PM
BobTurner BobTurner is online now
Bob, can you clarify: Was this with Cleveland pads, Rapco pads, or both? Is the issue heat buildup (fading)?
Old 10-11-2017, 08:45 AM
Strasnuts Strasnuts is offline
Default Here is one of the original posts on the Matco brakes.
http://www.vansairforce.com/communit...ht=matco+brake
A&P RV-10 Flying 850 hours
SuperSTOL Flying 100 hours
