Old 09-12-2017, 02:34 PM
I'm a bit curious about your numbers: 700 lbs plus yourself? Either you have a very light -10, or are planning on less-than-full fuel?
Either way, approach aft cg with caution. Remember that you have to come back to land, and as you burn gas the cg will move further aft.
Old 09-12-2017, 02:43 PM
JackinMichigan's Avatar
JackinMichigan JackinMichigan is offline
Hey, what do you know. You're right. I apparently forgot something in my initial calculations.
2700 - 1673 (empty wt) - 360 (60 gal fuel) - 250 (my butt) = 417 lbs.
That's a little more manageable. Thanks for catching that.
Jack and Dave Groat, father and son
RV-10 N1861G
Build #41389, started Oct 2012
Current status: 1st Flight 11/10/17
Old 09-12-2017, 03:29 PM
I strongly urge all -10 owners to write or obtain an Excell or similar spreadsheet for weight and balance. The issue is CG. There are a lot of -10's out there that can exceed the aft limit when loaded unless care is used. And, as I noted, you can start out okay but go out of limits during the flight due to fuel burn.
Old 09-12-2017, 03:39 PM
Auburntsts's Avatar
Default +1
This. I copied an Excel W&B sheet and modified for my plane. It has 2 separate graphs-- takeoff and landing. I run both to insure I'm good to go as I burn fuel.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 09-12-2017, 04:10 PM
jwilbur jwilbur is offline
I also noticed recently when I did my W&B that a lot of the reported numbers for wheel positions from the datum were exactly the same as what Van's publishes in their example sheet. My main wheels were something like 1.5" different from that (and I checked these measurements multiple times). I contacted Van's about the difference and they told me the published numbers are from the RV10 prototype and that our kits may very well be different.
I suspect there may be some 10's out there where the CG is not where expected even when doing the math correctly.
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
Pink slip - 7/2017
RV-10 Build Log
Old 09-12-2017, 08:55 PM
bob888 bob888 is offline
Kitty litter
Old 09-14-2017, 09:44 AM
Dorfie Dorfie is offline
Default Kroger water bottles packs of 24
I used the 24 packs of water bottles from Kroger. They weigh about 25lb each. The plastic wrap is pretty strong. 5 in the luggage compartment, 5 on each rear seat. The rear seatbelts holds them together well. Then have observer pilot with me, full tanks and I was at gross weight and not full rear CG.
Will still use the water later!
Johan
Dorfie
RV10
2018 dues paid with a smile
Old 09-14-2017, 09:55 AM
aturner's Avatar
aturner aturner is offline
My wheels also differed from the published datum.
-Andy Turner
RV-10 N784JC
Old 09-14-2017, 04:47 PM
DRMA DRMA is offline
If you have Foreflight on your iPad, you can use the W&B portion to give you a plot that shows your CG with both full fuel and empty.
Dave Macdonald
RV-10 Finishing Kit & FWF in-progress
2018 VAF Dues Paid
Old 09-14-2017, 05:34 PM
Auburntsts's Avatar
GarminPilot does it too.
Todd Stovall
PP ASEL-IA
WAR EAGLE!
