Old 09-11-2017, 11:11 AM
Mike K Mike K is offline
Default Canopy fiberglass work
Good afternoon-
Getting ready to start the fiberglass work around my canopy. Anyone have an idea how much resin I will need. I'm using the West system and can't buy local so want to have enough on-hand when I get started.
Mike
Old 09-11-2017, 11:40 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Originally Posted by Mike K View Post
Good afternoon-
Mike
This is what I purchased at my local West Marine store (Yes I know there isn't one close to you but you can order online to have shipped):
- Part 1 105-A resin (32 oz), Part II 206-A hardener (7 oz)
- quick pump kit
- 502 colored epoxy pigment
It really doesn't take much to do the canopy. This will be more than enough plus some for the whole plane.
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 09-11-2017, 12:32 PM
MED MED is offline
I have seen several folks do this, but is there an advantage to coloring the epoxy? It will eventually be covered with paint.
MED
140236
N435MD reserved
Old 09-11-2017, 01:21 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
The pigment if for the fiberglass that you can see thru the canopy
Rob Lasater
Rv-14 emp/fuse done working on wings and finish
Paid dec 2017
Old 09-11-2017, 01:30 PM
MED MED is offline
Ok, got it. How much do you use to get it dark enough? I have used a lot of Fiberglas on boats, but never tried dying it. Thanks.
MED
140236
N435MD reserved
Old 09-11-2017, 01:41 PM
Ron B. Ron B. is offline
It does not take much, I bought the smallest bottle I could and did not use much of it. I just mixed it in with the resin and kept adding til I got the desired look.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 09-11-2017, 01:48 PM
Depends on what color you use and how much resin you're using in the batch. This is something you'll need to adjust to your preference. Not to sound snarky but black is black.
Carlos in Arizona
Old 09-11-2017, 02:01 PM
MED MED is offline
Thanks for the responses. I guess I will just experiment to get it "black!"
MED
140236
N435MD reserved
Old 09-11-2017, 03:25 PM
Nova RV Nova RV is offline
Check on EBay - I got a small bottle 4 oz of boat fiberglass pigment for $14.50. You only use drops, not ounces to get a solid black color to the epoxy. Make sure you get the pigment for epoxy not polyester, not sure the difference but they are different products. The canopy fiberglass looks daunting but is not very difficult to do. Just follow the videos on Vans web site.
Chris Moon
Leesburg, VA
RV-14A kit # 140243
VAF 2017 and 2018 paid
www.mykitlog.com/chrismoon/
Old 09-11-2017, 03:46 PM
Thanks for the help, sounds like a quart should do.
