Old 09-10-2017, 11:22 AM
Adam W Adam W is offline
Default couple of fueselage questions - help please
hey all
does anyone have a decent illustration of the 6111 skin reinfrocement ribs in place or advice on the method used to cut and form them?
one more question.
i notice the manual would have me fix the baggage floor down permanently in another step or two
do i not need this open to pass wiring to the rear of the fuselage? or at least create a chase through one of the bagage floor ribs between 705 and 706 for later wiring? is this one of those spots not well addressed in the manual or is there an alternate route used by most for the wiring that has to reach the rear of the plane
thanks in advance
Adam Wachtel
Thornhill Ontario Canada
Building RV7 #70770
Wings done
Empenage done
QB Fuse done
Finish kit underway
Vans Airforce Dues Paid
Flying Piper Supercub PA18 150
Flying Cessna 414A
Old 09-10-2017, 11:42 AM
Carr Carr is offline
Adam
You will want to use under the baggage floor area for a lot of things.
I used plate nuts instead of pull rivets on the baggage floor so I can get to the transponder antenna and strobe control box. Most of the wire that goes to the back end can be run under as well.
If you are going to use pull rivets, wait as long as possible before doing so.
My 5 nickel ( we don't use pennies anymore)
Carr
Old 09-10-2017, 01:41 PM
thank you Carr
So you recomend drilling a hole and using a bushing in the bottom of 705 and 706 between baggage floor ribs for wire passage later?
Adam Wachtel
Building RV7 #70770
Wings done
Empenage done
QB Fuse done
Finish kit underway
Flying Cessna 414A
Old 09-10-2017, 02:10 PM
wirejock's Avatar
wirejock wirejock is offline
Default Pathway
You can but be sure to refer to Vans locations for snap bushings.
I went with removable floors and baggage bulkhead so I could use that area any time without drilling pop rivets. You don't know, what you don't know.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 09-10-2017, 03:18 PM
Thank you
How would one route their cabling if not through this a baggage floor?
I don't think the center space with the pushrods is a good option
Why not a conduit through this space and close it permanent?
Is there a reason to use this space to Mount anything component wise?
Adam Wachtel
Building RV7 #70770
Wings done
Empenage done
QB Fuse done
Finish kit underway
Flying Cessna 414A
Old 09-10-2017, 03:42 PM
Wingnut Wingnut is offline
Default Not yet flying,
but I ran some of the same black conduit I used in the wings. Ran two sections, one in each side of the plane under the seats and baggage floors. My friend (whose plane is flying) , ran both sections of conduit on the same side of the plane.
Con Kelley
RV7
Empennage and wings need tips
Fuselage kit "finished" (for the moment)
Finish kit and FWF in progress
Hartzell CS
Aerosport Power IO-360, Dual Pmags, AFP FM200 FI
C-150 at 7FL4 (sold)
www.mykitlog.com/cakelley
www.1379.eaachapter.org
Old 09-10-2017, 04:43 PM
sahrens's Avatar
sahrens sahrens is offline
I did not use nutplates on the baggage floor and wished I had, it would have made many things easier. I did run wiring down both sides of the center section "tunnel" area. I riveted small nylon tie locations on either side so I could secure the wiring bundles.
Scott Ahrens
RV-7 N818BG
Test flight in progress
Old 09-10-2017, 05:28 PM
Larco Larco is offline
There is probably a zillion RVs with conduit run under the baggage floor. some have used the 5/8" drip system tubing from the hardware store. Make it long enough to end in front of the seat pans.
Old 09-10-2017, 05:53 PM
rzbill's Avatar
rzbill rzbill is offline
I riveted the baggage floors per the plans and have never regretted it. No conduit goes through there.
My wiring hugs the sides of the center tunnel via Adel clamps.
Bill Pendergrass
RV-7A: Flying since April 15, 2012. 710hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
Old 09-10-2017, 07:35 PM
wirejock's Avatar
Default Pathways
Originally Posted by Adam W View Post
Thank you
The other answers are all fine. It really comes down to personal preference. Many use two of the corogated Vans conduits either in the tunnel or in other bays. Just obey the Vans direction on placement of holes and all will be fine. I wanted access so mine are removable. It adds a bit of work and about 1 lb of weight.
Yes, lots of builders use the spaces for equipment or terminal strips. Devices seldom accessed would be best.
Larry Larson
Estes Park, CO
Disclaimer
