Old 09-11-2017, 04:24 PM
1001001's Avatar
1001001 1001001 is offline
Originally Posted by gvouga View Post
Here's another option that is on Kickstarter
https://www.kickstarter.com/projects...ble-air-condit
http://www.zero-breeze.com/
I have no idea how well it works or if it is even in mass production yet. I just saw it on Kickstarter and thought it was cool (pun intended). It looks like they surpassed the funding goal so that's a good sign.
You'd need to have a duct going outside the aircraft to vent the hot air, otherwise you'd just get a net temperature rise inside the cabin.
Old 09-12-2017, 09:54 AM
Bluelabel's Avatar
Bluelabel Bluelabel is offline
Default I have one and use it
We brought one last year at Oshkosh and used it this year on our trip out.
It will fit though the baggage door of the 10, but you have to turn it sideways. Which means you have to load it after you put it in the baggage area. Not a big deal.
I rigged up a power outlet for it and we got the extension tube and the remote switch. I run the extension tube up and hang it on the seatbelt bracket. It won't cool the cabin as whole, because either there's so much air already moving around, or the sun is just too powerful. It will help take the edge off on the ground and cool the two front passengers when flying.
Overall, I'm pretty happy with it.
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Lead on the
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system
"so I got that going for me... which is nice."
2017 Dues Paid"
Old 09-12-2017, 10:14 AM
rvdave rvdave is offline
I've been thinking about creating a reduced passage through the baggage bulkhead and into the butterfly valve to get the air into the overhead. Seems that there was a way that one valve can close and the other one open. Gonna give it a try someday.
Dave Ford
Cadillac, Mi
Old 09-12-2017, 12:09 PM
N402RH's Avatar
N402RH N402RH is offline
How do you get it out once it melts the ice?
I have dumped cold water on myself twice getting it out of the plane and into the car.
Rob Hickman
N402RH RV-10
Old 09-12-2017, 12:28 PM
ppilotmike's Avatar
ppilotmike ppilotmike is online now
Rob Hickman
N402RH RV-10
Easy. Attach a long section of hose to the "return" and run it out the baggage door. Turn on the unit and it will pump all the water overboard, or at least enough to not worry about giving yourself a shower. Just make sure not to completely drain it dry, as running it without liquid in it could ruin the pump.
Mike Rettig
EAA Chapter 301, President www.eaa301.org
VAF Dues Current: as of 01/15/18
RV-10 (41PX Reserved) Fuselage
http://www.mykitlog.com/mikrettig
Old 09-12-2017, 12:52 PM
Bill Boyd's Avatar
Here's a thought. Use the AeroSport controller to cut off flow to the overhead from the NACA's in back. Force air from the ice cooler through its own opening into the overhead and let the chilled air come out the overhead vents. At altitude, open the NACA controller and let cool ambient air in. No biggie if some outside cool air back-flows through the ice cooler, right? Still ends up in the cabin.
No better time than right now to plumb this into mine while I build. I think the rearmost removable panel could host this secondary air inlet with ease. Would probably help a tiny amount to insulate the portion of the cabin top that's within the overhead. Also tinted windows and a non-black interior...
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 09-12-2017, 07:10 PM
vernon smith's Avatar
vernon smith vernon smith is offline
Bill, if you build that I would like to see some pictures
Old 09-12-2017, 08:22 PM
Avi8tor857 Avi8tor857 is offline
Read the comments on this kick starter and https://www.indiegogo.com/projects/z...t#/updates/all, I've wanted to order one but the company isn't communicating with the backers and has missed 3 dead lines ... now they say there is a problem with the power supply.
