Old 09-12-2017, 07:20 AM
Originally Posted by f1rocket View Post
As far as I know, the tractor regulator I put in my -12 is still going strong in the Texas heat 300 hours later.
Likewise, Ducati VR failed at 100TT and was replaced with John Deere AM101406 - does nice job maintaining battery voltage at 14V.
VR mounted on firewall shelf in original location with new 1/8" aluminum sub base for heat dissipation. Used heat transfer paste at the VR / sub plate.
Now 280TT and going strong. I don’t like electrical failures, so I have a 2nd JD on the shelf for $27.99 free shipping from eBay.
Hinckley, Ohio
P/ASEL 1970 Sport Pilot since '04
RV-12 E-LSA #120058 AWC 7/12 Bought Flying 10/15 with 48TT - Hobbs now 317
LSRM-A Certificate 2016
Old 09-12-2017, 10:57 AM
todehnal todehnal is offline
Hey Jim, are those true OEM John Deere AM101406 parts, or aftermarket regulators.................Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 09-12-2017, 03:35 PM
I'm pretty sure they are Chinese aftermarket...
Hinckley, Ohio
Old 09-14-2017, 12:10 AM
keitht keitht is offline
Default Regulator failures
The Ducati regulator is a marginal unit both from an electrical design, thermal design and mechanical design viewpoint. A friend with a RV-12 had a Ducati regulator fail within the first 40 hr of flight time. I carefully took the unit apart to determine the cause of failure and determine the circuit configuration.
The circuit uses a bridge rectifier configuration with two SCRs in opposing legs of the bridge. The firing angle of the SCRs is varied as the output voltage of the generator winding changes with engine rpm and electrical load to provide the regulated output. The SCRs used in the unit I took apart have a very high saturation voltage ( based on the data sheet for the part) so the efficiency of the unit and consequential thermal losses would result in high unit temperatures. The design of the control circuit is almost identical to a readily available circuit schematic available on the web. Ciruit component values were a little different but the topology was the same. The thermal design and mechanical design were very poor. Both SCRs and one power diode in the bridge had failed in a short circuit mode typical of an over temp condition. Analysis of the control circuit showed that not getting a good 12 volt reference could result in unstable operation of the regulator and induce premature failure. The airplane wiring schematic shows the 12 volt reference to the regulator going through a large number of connections to go from the master relay to the regulator. The regulator was replaced and the 12 volt reference wired directly from the master relay to the regulator. The location of the regulator on the engine side of the firewall was left the same. So far the second regulator has over 120 hr and 12 months of operation without failure. The Ducati regulator is truly a weak link in the electrical system for the RV-12. I was hoping there would have been a robust alternative by this time.
Old 09-14-2017, 12:43 AM
Default Regulators
Another consideration when swapping out the Ducati regulator for some other alternative.
The engine alternator windings are in the same magnetic circuit as both ignition circuit generator windings. So theoretically saturation of the generator magnetic circuit could result in no voltage to the two ignition circuits and engine stoppage. I dont know if this is a practical possibility - would very much depend on the tightness of the magnetic coupling and the saturation characteristics of the engine generator. Since it is unlikely that Rotax would provide any electrical design data on which to base a more detailed analysis the only way to be sure that a regulator failure couldnt take out the ingnition circuit would be through extensive testing
Just a concern about using any new regulator without detailed analysis and testing.
Old 09-14-2017, 12:50 AM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
Default Get the SH regulator for less
How are you guys doing who have replaced your original Ducati with the Silent Hektik design? Too bad they are so hard to get, and the cost is so high; nearly $300 shipped from a motorcycle dealer in England.
Tom
Simply order the VR directly from the manufacturer. According to their web site they ask
165.- (excl. tax) for it
https://www.silent-hektik.de/UL_R_912.htm
Chris, RV-12 HB-YSC
Preparing for final assembly
Facebook: http://www.facebook.com/magic.carpet.aviation
12-Town:http://12town.com/profile/Chris
=VAF= dues paid for 2018
Old 09-14-2017, 07:32 AM
Super Moderator
Default Cold solder joint
Out of curiosity I took apart the failed regulator to understand the root cause. It was a cold solder joint on a large wire on the printed circuit board. Clearly the board is wave soldered and that might not be the best for large wire protrusions. I had to use a Weller 100W soldering iron to get it to form a good solder joint, and then I tested it on the aircraft.
Worked like a champ, with 13.7 volts right at startup and solid battery charge of 5 amps and decreasing (meaning the battery was completing its charge). Prior to that I had 11.5 volts showing on the battery and -6 amps discharge.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Van's East Coast Representative
www.Baselegaviation.com
Old 09-14-2017, 08:24 AM
. . . . the 12 volt reference wired directly from the master relay to the regulator.
The disadvantage of doing that is that there is no way to shut off electrical power in case of smoke in the cockpit. Shutting off the master contactor will not shut down the charging system because the "C" terminal will still be energized by the regulators output. I know because I experimented. When wired per above, everything kept right on working when the master switch was shut off, although the voltage was unstable, varying plus and minus about a volt or so, setting off the Dynon high voltage alarm.
Joe Gores
RV-12 Flying
Old 09-14-2017, 12:01 PM
Yeah, that's easy for you, living in Switzerland. I emailed them and they do not ship to the USA. That means that we have to order through a 3rd party, and the only source I could find was a Moto Guzzi dealer in Europe who does ship to the USA. That is where the $300 US quote came from. Lucky you!
Tom
Old 09-22-2017, 09:13 PM
ramrod25 ramrod25 is offline
I happen to be flying a Kitfox at the moment, but since I have the same engine, a Rotax 912 ULS, I like to monitor your forum; it has lots of good Rotax info.
I too lost a regulator. I replace it with a NAPA SME 7068102.
My regulator is inside the cockpit and I mounted a 5" 12 volt cooling fan that blows directly on the regulator. Wired it into the master switch, so anytime the power is on, the cooling fan is running. Have flown well over 100 hours now with no further issues. Puts out 14.7 volts and will handle up to 20 amps.
I think it's important to keep these regulators as cool as possible; the dedicated cooling fan seems to be working well.
I got the idea for using this regulator from this forum; there is a good thread on here that recommended the NAPA regulator.
Regards
Rodney
