Old 09-06-2017, 02:09 PM
dick seiders dick seiders is offline
Default Engine isolator
In the process of Confition Inspection and in checking all undone SBs, safety alerts, and Notifications I find I can't find the required (number BC-22002) engine isolators with numbers so I may have to pull my engine to meet the requirements of 16-08-10. Not a pleasant discovery.
My serial no. 120093 is obviously one of the early birds. My question is has anyone else had to make this change?
Dick Seiders
Old 09-06-2017, 02:55 PM
Phantom30's Avatar
Phantom30 Phantom30 is online now
Dick Seiders
Didn't have to do it; but several have, stating isn't really that bad. Rent a engine hoist...do top ones first (loosen bottom ones and pivot engine down enough to pull top ones)...bottoms a reverse of tops.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 09-06-2017, 07:26 PM
I like the idea but wasn't sure I could get enough movement without disconnecting most components. If some have used that approach I feel more confident about giving it a shot. Thanks for the feedback.
Dick Seiders
Old 09-07-2017, 05:46 AM
todehnal todehnal is offline
I had to do mine. The only thing that I took off was the cowling, 2 air filters, and the tunnel harness cover. Then, I hooked up my little hoist and put a little lift tension on the engine. I actually loosened all 4 nuts way off to give a little wiggle room. I took the nuts off 2 at a time and aligned the lift to ensure free bolts, then my daughter swapped the mounts while I swung the engine as required. You only need about 3/8" to clear the mount cups. All total, about 2 1/2 hrs, including taking out the carpet and removing the tunnel harness cover. Don't over think it. It's not a big deal..............Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 09-07-2017, 01:07 PM
ben barron ben barron is offline
Default Double check
Before you do the replacement look VERY CAREFULLY. I took a second look with a bright light and clean glasses and found the numbers faintly along the edge of the washer.
B2RV12
Old 09-07-2017, 01:48 PM
DaleB's Avatar
DaleB DaleB is offline
Amen to that. I finally found the letters the third time I looked, with a bright LED light and a mirror. The very tops of the letters were just visible at the edge of the metal cup.
Dale
Omaha, NE
Previous RV-7 project (sold)
-=VAF=- 2017 dues paid
Old 09-11-2017, 07:46 AM
Thanks for the input I tried to look the letters on it it just would t work. Will change them this week after Irma leaves.
Dick Seiders
Old 09-12-2017, 10:19 AM
DaveWelch DaveWelch is offline
Default 2nd look
I had to look twice also.
Finally saw the lettering on all of them. In some cases you can't see the lettering straight-on but it reveals itself "in shadow" of the light at an angle.
Also, a careful re-read of the bulletin stated that you will find the lettering on only 1/2 of each pair. Big relief, I was looking for it on both.
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
Old 09-13-2017, 04:38 PM
Dave12 Dave12 is offline
I just swapped mine out. Wifey and I were planning a flight to Belfast, Maine for the third annual rv fly in and I thought since I had the cowl off to look it over, why not swap them out. Took about 2 hours total. Come on up to Belfast, the wx is beautiful!
Wag Aero Sport Trainer
N588DF RV12 #336 Sold
N73DF RV12 #244 Flying
Old 09-16-2017, 02:58 PM
Tod
Did you remove two top bolts at same time or top and bottom on one side, and does it make any difference? I have the keys out and will switch them out tomorrow.
Dick Seiders
