Old 09-06-2017, 11:53 AM
8317R 8317R is offline
Default RV6 Electric Flap Motor
My RV6 flap system was manufactured in the early 2000's. Since 09 when it was licensed I get about 3 doz cycles before the motor quits. Yes, we land with no flaps, adds a little excitement. Take the motor apart, clean the brushes and commutator and it is good for another 3 doz cycles. Does anyone have a fix for this other than replace the motor. The original manufacture of the motor does not support this model anymore and only wants to sell me a new motor.
Old 09-06-2017, 12:11 PM
JonJay's Avatar
JonJay JonJay is offline
There was a time when the flap motor assembly was manufactured with too much grease. That grease migrates and fouls the motor. Removing the excess grease usually fixes this issue.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 09-06-2017, 12:32 PM
bhester's Avatar
bhester bhester is offline
Thumbs up Get a new one
Mine did that a number of time, I took it apart and cleaned it a number of times, then I ordered a new one. It came full of grease. I cleaned it real good before installing it and it has worked great ever since.
No matter how good I cleaned the first one it keep doing it.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2017 VAF donator - alot better than any magazine subscription
Old 09-06-2017, 10:56 PM
lr172 lr172 is offline
My flap motor was shipped in '00. Based upon all of the comments here, I fully disassembled the gear section of the unit and cleaned it. I left only what I felt was an appropriate amount of grease (far less than the guy/gal at the factory felt was appropriate). 400 hours without a problem.
When you cleaned the motor, did it have signs of grease? If so, take apart the gear section and remove all of the excess as well as degreasing the entire motor and it's housing.
N64LR
