Old 09-06-2017, 05:50 AM
Tbone's Avatar
Tbone Tbone is offline
Default Baffle Clearance
What are the dimensions used on the clearance needed on the forward inlet ramp/cowling area? My -7 has fuel injection so I don't have much free clearance due to the filter. My cowl to spinner gap is not overly tight but trying to see what would be the minimal clearance on inlet ramp to cowling gap. Thanks!
___________
Terry
RV7
XP IO360
Old 09-06-2017, 10:25 AM
flion's Avatar
flion flion is offline
By filter clearance, you mean you have horizontal induction and a snorkel? Because the filter on my vertical induction IO-360 has no bearing on the cowl fit. But in any case, I found that 3/8" at the upper inlet ramps is a good gap to allow the baffle seal material to fit tightly and still allow the cowl to drop for removal. For those without the snorkel, 1/2" is good for the inlet to the FAB; the cowl moves more there as it is removed. If I had it to do again, I'd go with larger gaps to make the cowl even easier to remove; minimal is not cosmetic when there's the gap seal covering it.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
Old 09-06-2017, 05:45 PM
Tbone's Avatar
Default Of course
Yea thanks for the clarification. I wasn't thinking about a vertical injected setup. Mine is horizontal with snorkel. I may have to cut back my cowling inlets to get the clearance needed. With my K&N filter as far aft as it can go I only have about 1/8" clearance from the cowling. I don't want to cut no more than needed. I wonder what the minimal would be?
___________
Terry
RV7
XP IO360
