Old 09-05-2017, 06:46 PM
Louavul's Avatar
Louavul Louavul is offline
Default Which Cowling Hinge
Guys: Planning to use the Van's supplied hinges to attach my cowling. Unfortunately, I've become confused as to which hinge, 1/8"/large or .090/small, is installed where.
Please confirm my thought that the larger hinge (1/8") is used at the firewall to the cowling aft attach edge, upper and lower, and the smaller hinge is used to join the cowling halves (upper to lower).
I do understand about using the .090 steel pins in the large hinge.
Its got to be my brain catching up to my age.
Many Thanks,
Steven Hild
Rio Communities, NM USA
RV-7, FWF/Fiberglass, N590SC res
Contributing annually since January 2002
Old 09-05-2017, 07:27 PM
rv7charlie rv7charlie is online now
Large across the top, with small pins. Large on the sides, with large pins.
