Old 09-08-2017, 01:20 PM
bruceh's Avatar
bruceh bruceh is offline
Gear leg fairings?
Bruce Hill
RV-9A N5771H flown over 500 hours!
2017 VAF donator
EAA Tech Counselor
Old 09-08-2017, 03:04 PM
N999BT N999BT is offline
Default Gear Leg Fairings
I thought of that, but since they don't move at all I figured it couldn't be them. When fast it rolls right, slow it rolls left. I think it has to be airflow around the ailerons...
Brent Travis
N999BT
Flying
Old 09-08-2017, 03:49 PM
Default huh?
This suggested to me the current fix may not be the correct one. Maybe an issue was compensated for and not corrected, hence the "fix" only balances out that tendency at one airspeed? JMHO
Thank you
John S
Fuselage started
Old 09-08-2017, 06:04 PM
Berchmans Berchmans is offline
Default Elevators?
Are the elevators in alignment? I once had a yaw problem on my float plane ( I know not related) turned out that when retracted the water rudders were out of alignment. Elevators could cause a roll tendency of properly aligned.
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2018
Old 09-08-2017, 06:13 PM
jklusman jklusman is offline
My RV-8 had a heavy left wing when I bought it in 2013. I followed a suggestion I think I read on this forum, and it immediately fixed the problem. The suggestion was: Cut a small coffee-stirring straw in half and tape it to the bottom aft end of the opposite aileron, parallel to and about 1/4 inch forward of the trailing edge. Use clear packing tape to secure the straw. I secured the straw roughly in the middle of the aft aileron span. The straw and tape have remained in place for 4.5 years. This sounds too easy to be true, but I'm not joking -- it did the job.
Old 09-08-2017, 11:48 PM
rv8ch rv8ch is offline
Default good tip
Gonna file this one away for the future. Another example showing aerodynamics is complex.
Mickey Coggins
http://rv8.ch
Old 09-09-2017, 06:53 AM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Elevators
When I was aligning my elevators, I used an 8' alum. straight edge on the trailing edge. I discovered that elevator horns (where the counter weights are mounted) did not align with the horizontal stabilizer. If one side was flush, the other was off by 3/16". I had a choice, either a straight trailing edge or misalignment with the counter balance arms meeting the HS. Vans, told me this was a common problem. I chose the straight trailing edge. A friend did the opposite aligning the horns, he now has a heavy wing. Just a thought, check out your elevator trailing edges with a straight edge.
Al Girard, Newport, RI
N339AG
RV-9
Old 09-09-2017, 07:06 AM
David-aviator David-aviator is offline
FWIW - Solved heavy left wing by slightly squeezing right wing aileron bend full length.
Then had heavy right wing!!
Squeezed left wing aileron slightly at one panel between ribs, airplane now flies wings level by itself.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
I'm in, dues paid 2018 This place is worth it!
Old 09-09-2017, 01:09 PM
Aluminum Aluminum is offline
In other words, a Gurney flap?
https://en.wikipedia.org/wiki/Gurney_flap
Old 09-09-2017, 05:59 PM
The of the different advice and ideas is great, but a lot of it misses the mark.
If there is a problem related to the ailerons (likely since the OP said if he manually holds the ailerons in neutral, the airplane fly's straight), then using a lot of different methods to counter the roll, but totally bypassing fixing the actual problem is not the sensible way to fix it.
BTW, split alignment on elevators has very little (if any) noticeable influence on roll trim. You need to think about the leverage available... The elevators are very short in span compared to the wings. Any roll they can induce has a very small moment. That is why adjusting the flaps has only a very small effect on roll trim.
The ailerons though have a large moment way out at the end of the wing. That is why a very small aileron abnormality have a large influence on roll trim.
Just squeezing the trailing edge is not totally the correct way to solve a roll trim problem. You could do that and get the trim adjusted, but still have two ailerons that are equally not the correct shape.
As I mentioned previously, the very first thing that should be checked is that the ailerons themselves are actually built to the correctly (primarily trailing edge shape).
Scott McDaniels
Hubbard, Oregon
