Old 09-04-2017, 08:06 AM
AeroDog AeroDog is offline
Default Page 35-03 Painting main gear legs
The build manual is clear: The main gear legs are to be painted with two-part epoxy primer, then painted. The legs are shiny and pitted as a result of bead blasting I'm told. My question regards prep for the primer. Should Alumaprep and Alodine be used or is thorough cleaning enough? (Yes, I used the search function.)
Jerre
Empennage and fuselage kits complete
Wing kit compete, Finish kit nearly complete
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2018
Old 09-04-2017, 10:33 AM
rongawer's Avatar
rongawer rongawer is offline
If you're using a modern self-etching epoxy primer; if desired, scuff with a fine grit sandpaper, wipe clean with acetone, mineral spirits, or whatever prep the primer calls for, and prime.
Ron Gawer
- RV12, N975G, SN 120840, All done with construction ...kinda. Next step is moving to the airport.
- BE58, N1975G, stimulating the economy one flight at a time.
Old 09-04-2017, 10:39 AM
Because of the blasting texture, etching with a surface prep containing phosphoric acid (aluma prep, etc.) is the best way to assure a surface that is 100% cleaned of oxidation before primer application.
Scott McDaniels
Hubbard, Oregon
Old 02-13-2018, 09:12 PM
DaveLS DaveLS is offline
Default Powder coat?
Can the main gear legs be powder coated?
Old 02-15-2018, 08:02 PM
rolick22's Avatar
rolick22 rolick22 is offline
I'm going to say yes on the powder coat because the new finishing kit main gear legs are.
_____________________________________________
David Rohrlick
PPSEL A&P
RV-12 Finished (Empennage, Fuselage(1st gen), and Wing kit)
iS Finishing Kit In work
iS Fuselage Kit In work
1st GEN FUSELAGE SOLD
Serial#12-0864
N864DR Reserved
