Old 09-03-2017, 11:06 PM
sglynn's Avatar
sglynn sglynn is offline
Default Route Pitot/Static thru Spar
Is there another place to route pitot/static thru spar box in fuselage of my RV-7A?
I need to route the pitot/static lines up to panel because I'm adding a Dynon D6 for backup and it requires them. Problem is all my wiring is done and the 4 holes thru the spar are full of wires. Is there another way to route the Pitot and Static tubes thru the wing spar in the fuselage? Static tube will go under the top ledge coming forward from rear. Pitot/Static come in from wing and need to split and go aft for ADHRS and forward for D6 EFIS.
I've been searching the archives and haven't seen a specific ideas for getting the two lines from behind the spar forward to panel. Can I come in under floor and then go up to under the arm rest or top rail?
Photos most appreciated.
Steve Lynn
RV-7A
90% Finished
Working on Wiring
Only panel left to go.
Anacortes, WA
www.mykitlog.com/sglynn
Old 09-03-2017, 11:38 PM
In my 9A, I ran my lines under the top of the longeron. You have to cut or grind a bit of the side of the center section bulkhead so they will fit. Then I ran them down the sidewall and drilled 2 small holes through the armrest and seat pan. I put a coupling fitting to connect them to the lines from the pitot. If I were doing it again, I would use the real small and flexible lines. They run as easy as an electrical wire and will give you the same results as the bigger lines. You will need a junction fitting at the pitot if you are using a garmin, but worth it.
Good luck. Email me if you want a picture. Too much trouble to post here.
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Old 09-04-2017, 12:15 AM
David Lewis David Lewis is online now
Default Van's Solution
Years ago, RVator published a Van's solution for this: Under the longeron as rockwoodrv9a stated. Here is a rather low resolution PDF of the article.
https://www.dropbox.com/s/m0ybnh0p17...cline.pdf?dl=0
David Lewis
RV-7A
Empennage complete
Wings complete
Fuselage complete
Working on Canopy
Old 09-04-2017, 12:46 AM
az_gila's Avatar
az_gila az_gila is online now
Exclamation What the factory says...
Perhaps this file from Vans web site may be of help?
http://vansaircraft.com/pdf/Routing_..._Bulkheads.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-04-2017, 11:11 PM
sglynn's Avatar
Default Holes thru bulk heads
This last document Gil sent shows places I can drill a new hole. I had not seen this. Much appreciated.
Steve Lynn
RV-7A
90% Finished
Working on Wiring
Anacortes, WA
Old 09-05-2017, 07:19 AM
BillL BillL is offline
Default Stiff as elephant hair, but submits to heat.
Hi Steve,
You can heat and bend that tubing too. It is tough to get it neatly routed if you don't. Try it on a spare end to get the feel of the bend radius. You will like it. I did some in place with a wooden radius tool down in a limited hand space location.
Bill
Op Lims in hand 12-7-17
Prep for 1st flight underway.
2017 Dues Paid
Old 09-05-2017, 11:59 AM
sglynn's Avatar
Default New Allowed Penetrations thru center section bulkhead
Has anyone used the guidelines in this fairly recent report from Van's, that Gil shared, to drill a new hole thru the center section bulkhead (wing box)? If so could you share where that met the guidelines?
thanks
Steve Lynn
RV-7A
90% Finished
Working on Wiring
Anacortes, WA
