Old 09-04-2017, 06:31 PM
Sam Buchanan's Avatar
hall monitor
No argument that the more expensive guns are nice tools. But the H-F 3/16 gun was adequate to build my Fokker D.VII replica which is a riveted tube-n-gusset airframe. The key to getting good service from the H-F gun is to carefully adjust the pulling mechanism. This is not a difficult operation but makes the difference between operating smoothly or being frustrated. I agree that two of these inexpensive guns would be a nice combination.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 09-04-2017, 06:38 PM
Sam,
Is there a guide on how to adjust the mechanism? Adjusting mine has never crossed my mind.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 09-04-2017, 09:13 PM
sandpiper sandpiper is offline
My third HF gun has performed without a problem. The first two went back to HF and were immediately replaced.
Now, if I'd have picked up the third one first..............
John Horn (donated for 2018)
Independence, OR
LSRM-A, CFII
Rotax Service, Maintenance, and Heavy Maintenance Trained
Building an RV-12, N7878H reserved
Flying a Flight Design CTSW
Old 09-05-2017, 03:05 PM
Bobo Bobo is offline
What is the best type of hydraulic fluid to use in these pneumatic pop rivet guns?
Todd Rader
Old 09-05-2017, 03:54 PM
hall monitor
Originally Posted by Kyle Boatright View Post
Sam,
Kyle,
Here is a photo showing the inside of the H-F gun:
The position of the black collet on the threaded shaft determines how tightly the rivet nail will be gripped. The lock nut can be loosened to adjust the grip. This is a very fine adjustment, too tight and the nail won't be released, too loose and it might take more than one pull to set the rivet. The collet needs to be adjusted in small increments until the rivet is set smoothly and the nail released. This is also a good time to clean and lightly lube this assembly.
Sam Buchanan
1999 RV-6
