Old 09-02-2017, 09:36 AM
JRo JRo is offline
Default sudden stoppage
We talked about the nose wheel fork failure on my RV-12 last week. Now I'm focused on repairing the damage as a result of the failure. The engine was at idle, near the very end of the landing roll when the failure occurred. The prop struck, and sudden engine stoppage occurred. Does the Rotax 912 need to be removed and torn down? Or once the reduction gearbox has been inspected/repaired/replaced and a dial meter shows the engine crank OK, can the engine be left in place? Thanks. JRo. N448JR
Old 09-02-2017, 10:25 AM
gfb gfb is offline
There are a few good threads on this, including links to the service manual explaining exactly what to do. Do a quick search
I even found a youtube video of how to do the inspection!
RV-9A - Emp, Wing, Fuse, Finish, Electrical, Avionics complete, FW FWD 90%, F&$*ing Baffles...; started 01/2015.
Titan XIO-340 mounted!
Old 09-02-2017, 10:45 AM
mfleming's Avatar
mfleming mfleming is offline
Not sure if this doc is the most current but it may help.
http://www.dulfu.dk/CustomerData/Fil...195_d05178.pdf
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Empennage (sans fiberglass)
Ailerons and flaps complete.
Wings done (sans fiberglass)
Started on QB fuselage
Donated 2017
Old 09-02-2017, 02:35 PM
rolick22's Avatar
rolick22 rolick22 is offline
Default lower cowling
If you need a lower cowling thats brand new let me know I have one. PM me
_____________________________________________
David Rohrlick
PPSEL A&P
RV-12 Finished (Empennage, Fuselage, and Wing kit)
Finishing Kit on Hold
iS Fuselage In work
1st GEN FUSELAGE FOR SALE
Serial#12-0864
N864DR Reserved
Old 09-02-2017, 07:23 PM
waterboy2110 waterboy2110 is offline
You can check the crankshaft distortion while it's in the plane but there's really no access to the back of the engine while mounted. I'm told it's rare that a prop strike will twist the crank where composite props and the overload clutch are present.
The process for the crank is in the Heavy Maintenance Manual from Rotax.
There are also several service letters referenced in 05-50-00 of the line maintenance manual.
After any propeller strike the following inspections must be performed
before operation can continue.
Step Procedure
1 Inspect the engine for damage. If any damage is detected, inspect, repair
or overhaul the whole engine in accordance with the relevant Manual.
Inspect all systems for correct functioning.
2 Inspect add-on components e.g. propeller governor, vacuum pump, external
alternator. Observe the manufacturers instruction(s).
3 Observe the directives from the aircraft manufacturer.
4 Remove the fuel pump and gearbox.
5 Remove the roller bearing in crankcase for propeller shaft.
6 The whole gearbox must be inspected, repaired or overhauled in accordance
with the BRP-Powertrain instructions for continued airworthiness -
but not limited too
- Carry out detailed inspection of all gearbox components.
- NDT for cracks on gearbox housing, propeller shaft and gear set.
- Inspect drive for governor and vacuum pump (if fitted).
7 Inspect the crankshaft on the power take off side for out-of roundness. See
chapter 72-00-00 section 3.9) of the Heavy Maintenance Manual.
8 Re-install the gearbox.
http://jimsrv.blogspot.com
PP - ASEL
Instrument Rating
A&P / Rotax iRMT 9 Series Maintenance
RV12 Flying.
