Old 08-30-2017, 02:59 PM
petersb petersb is offline
Default Pricing Advice for RV9A please
Trying to establish a fair price for the following aircraft:
RV9A slider 10 years old:
o-320 out of a cherokee zero timed with high compression pistons - 300Hrs SMOH ( first overhaul for this engine )
Fixed pitch sensonich prop
Nice Paint and build quality
Standard Vans round guages with TruTrack autopilot
Mode C transponder and SL40 radio
Aircraft in Canada
Any builder gotchas to look for, I have built an RV6 and an RV7A, not too sure what to look for in the RV9A. Are the rear stabilizer mounting bolts to the fuselage longerons as tricky as the 7 ?
Thanks for any advice.
RV7A New Dec 2013 - 360, C/S, slider
RV6 - 1600 Hours ---- Sold
Old 08-30-2017, 03:33 PM
Beancounter Beancounter is offline
Default value
Flyboy1963 out of B.C. sold a similar plane recently.
C-GVMK
RV9a Slow(ly) built
Flying as of July 2012
Old 08-30-2017, 07:10 PM
Thanks, couldnt find his old add on the net. Saw his plane at Edenvale Ontario recently
Old 08-30-2017, 07:31 PM
grubbat's Avatar
grubbat grubbat is offline
Since you've built two, you know the first place builders learn on is the tail and so that is where you should start. Misdrilled longerons, improperly shot rivets covered up with primer, and so on. The fuselage longerons are as tricky as the 7 and many screw this up. Also, the -9 has the flap attach service bulletin so check for cracks on the wing rear spar. This should keep you occupied for a little bit.
As for value, if it flies, between $25,000 and $75,000.
Good luck on your purchase!
Craig
RV-3 Sold
RV-6a Sold
RV-9 IO-360 CS, Flying
1946 Piper Cub - in process......
Old 08-31-2017, 07:28 AM
Cant see a flap attach bulletin on Vans site, saw rear spar aileron attach rivits to rear spar though
