Old 08-29-2017, 10:54 AM
N999ZA's Avatar
N999ZA N999ZA is offline
Default RV-7 Wing: What would you do differently next time?
After reading through the following thread...
http://www.vansairforce.com/communit...d.php?t=127998
... I did a quick search of the -7/-7A forums and couldn't find an existing thread.
So, If you'd build another RV-7 Wing, what would you do differently ? Any features you would add to improve the serviceability of your aircraft, and that would be easier to implement while you'd be building the wing?
Andrew Z.
Engineering Flight Test Pilot/Engineer, CFI-A, CFII
RV-7 Kit (Halfway through wings)...SOLD!!! Then repurchased!!!!
2017 Dues Paid
Old 08-29-2017, 10:55 AM
N999ZA's Avatar
Default RV-7 Fuselage: What would you do differently next time?
So, If you'd build another RV-7 Fuselage, what would you do differently ? Any features you would add to improve the serviceability of your aircraft, and that would be easier to implement while you'd be building the fuselage?
Andrew Z.
2017 Dues Paid
Old 08-29-2017, 11:17 PM
Naigool Naigool is offline
Default No QB
I would go for a SB and not QB!
I found out very difficult to achieve certain build task that wasn't achieved on the QB fuselage.
Exemple drilling for the rudder pedals when the fuselage is almost done; not easy to do it properly and so easy to do it at the beginning of the build ( SB).
Installing the tail wheel support WD-409 was also a pain in the *** and the work will always be not as well done as if you build a SB.
So because I like the things well done I would avoid the QB!
Old 08-30-2017, 07:42 AM
Raymo's Avatar
Raymo Raymo is offline
I installed the Super Track while building and very glad I did. The one I wish I'd done is the Almost -14 mod to provide more room for taller passengers. I set mine up for my 5' 8" frame but anyone over 6 feet is cramped.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 08-30-2017, 08:18 AM
tgmillso tgmillso is offline
What I would do the same:
- Wet rivet (sikaflex pro) all skins on the lower half of the fuselage for corrosion protection.
- Titanium belly plate 14" wide and 2ft aft of firewall with 1/16" fiberfrax insulation.
- Mounting brackets for wing root gascolators on each side of the fuselage.
- Fiberfrax (I used morgan superwool as it is biosoluble) firewall insulation behind 2thou stainless foil. I used 1mm superwool, but next time I would use 2mm. I think the pillowing is too much with the 3mm (1/8").
What I would to differently next time:
- Perhaps get a QB so that I would not make so many customizations and not have to spent days wrenching on those longerons.
- I pre-fabricated many of the components according to the plans ahead of time. This was ok regarding edge finishing of sheets, but for many of the more intricate angle components (e.g. rudder stops) they had to be later modified regardless (or fabricated a second time) for a custom fit. Sure, prep and prime all your skins in one go, but for the smaller components build them as you need them and just hit them up with some quality zinc phosphate etch rattle can primer as you go.
- Wet rivet/fay seal the top skins on the fuselage. I did just the bottom skins for corrosion protection, however I should have in hindsight taken the time to do it to the top skins also.
- Baggage floor hatch and extra conduit running aft under the baggage floor. I thought I had plenty of room to run everything aft, but I don't. Way easier to install early.
- Give yourself plenty of room for fuel line bends. I used an andiar pump and didn't give myself enough room for the flaring tool to be placed on the pipe after I had completed the bends, so I had to spend a lot of time modifying things.
Tom.
Old 08-30-2017, 08:25 AM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default pro seal the belly seams.
I would pro seal all of the belly seams.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
flying with more than 1,650 on the hobbs
Race 771
margarita!
Old 08-30-2017, 08:39 AM
I'd order the delux fuel caps before I started the tanks. I got halfway through the tanks and realized that the standard tank caps and flanges are sub par, then had to wait a couple of weeks for the delux units to arrive.
Tom.
Old 08-30-2017, 09:13 AM
dave4754 dave4754 is offline
Default Pretty happy here
I bought the QB fuse and could not be happier it came in good shape.
Saved me hundred or more hours of build and as i am time constrained when building this helped me immensly.
Just my thoughts.
Dave Cobb
=VAF=2017 Donation - and a bit extra for great work!
Empennage RV 7 - Tipper
Wings complere
Fuse coming along, Canopy looking good!
AME reviewed and repaired O-320-Lyc installed
Old 08-30-2017, 09:24 AM
LittleDave LittleDave is offline
Control the bucking bar better......
Saves money on more skins.
David Campbell
RV7 empennage and wings complete, working on the fuselage
Old 08-30-2017, 12:27 PM
N999ZA's Avatar
Thanks for the notes, guys, all great for planning.
Moderators: Any reason why you combined my Wing and Fuselage threads?
I was hoping to keep them separate to let the building planning wing mods have a different place to go than the builders planning their fuselage mods.
Can we split them back out?
Andrew Z.
2017 Dues Paid
