Old 08-28-2017, 05:38 AM
JRo JRo is offline
Default RV-12 accident - August 2017
Saturday after a normal gentle touchdown at 5B7 the nosewheel departed the aircraft. After skidding a few feet on the nose strut, the strut folded and the prop struck the surface, resulting in sudden engine stoppage. the separated nose wheel struck the right stabilator, resulting in considerable damage to the stabilator. No injuries. Initial inspection of the recovered wheel shows a clean break in the nose wheel fork at a weld point. No cracks were observed prior to this event, even though fork had been carefully inspected in compliance with SB.
Old 08-28-2017, 05:42 AM
How many hours on the aircraft? Rough field operations or mostly paved runways? Any botched landings prior such as nose wheel strike?
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 350
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 08-28-2017, 06:00 AM
JBPILOT JBPILOT is offline
Default Pics would really help - -
especially of the actual break area. Thanks
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-4-18 )
Old 08-28-2017, 08:16 AM
I imagine everyone realizes that it is not possible for a normal/gentle landing to fail the nose fork on an RV-12 unless it already had previous (possibly missed / undetected) damage........
Scott McDaniels
Hubbard, Oregon
Old 08-28-2017, 09:11 AM
DaleB's Avatar
DaleB DaleB is offline
That's what I would think... so how do you think people are missing the existing damage/cracks? Is an external inspection enough, or could the cracks be starting on the inner parts of the fork and not be visible from the outside without complete disassembly?
I've inspected mine in detail twice recently, once just after the notification was published and once during the condition inspection. I cleaned it off and inspected closely, but stories like this have me wondering if it's enough. I don't recall ever abusing the nose wheel, but I'm not the only person who's flown it.
Dale
Omaha, NE
Previous RV-7 project (sold)
-=VAF=- 2017 dues paid
Old 08-28-2017, 09:23 AM
DonFromTX's Avatar
I am guessing that the crack was at the area where the weld and the base metal join. Often there is what almost appears as a crack there, but is just part of the weld process, when that crack follows the irregular path of the edge of the weld, it is easy to miss unless inspected very closely..
Retired US Army Officer
Old 08-28-2017, 09:31 AM
snopercod's Avatar
Is the fork steel or aluminum? It seems like magnaflux or dye-penetrant inspections might be advisable as part of the annual condition inspection.
(2018 dues paid)
Old 08-28-2017, 10:05 AM
DonFromTX's Avatar
It is aluminum.
QUOTE=snopercod;1199640]Is the fork steel or aluminum? It seems like magnaflux or dye-penetrant inspections might be advisable as part of the annual condition inspection.[/quote]
Old 08-28-2017, 10:09 AM
2johns 2johns is offline
Best way to take care of the problem is to buy the new heavy duty fork. That's what I did. Years ago I made a bad landing with my Long Ez, broke the lighter duty nose fork that I had not replaced with a new heavy duty one. It flew back and trashed my prop. Live and learn!
Old 08-28-2017, 11:18 AM
Larco Larco is offline
If I understand this correctly, If the fork is not visible for an inspection as a preflight option and is subject to sometime acquiring a crack or breaking at the weld. Why not replace the fork with the updated version??? The cost of doing so versus the optional outcome seems to be a no brainer?? Just saying
