Old 08-26-2017, 08:32 PM
Atanyspeed Atanyspeed is offline
Default Tow bar for RV-14A?
Wondering what other builders are using for a toe bar for a RV-14A. I'm about to put the landing gear on and want to be able to move it around once on the rubber.
Craig Wheeler
San Diego, CA
RV-7A Sold
14A Tail Cone complete
Finish kit somewhat finished
QB wings and fuselage Inhouse
Old 08-26-2017, 09:32 PM
czechsix's Avatar
czechsix czechsix is offline
I would imagine whatever the RV-10 guys are using would also work for the -14A but it would be good to confirm before purchasing.
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 08-27-2017, 07:09 AM
Nova RV Nova RV is offline
I bought some auto "skates" and put them under the wheels, now I can move the plane in any direction. Downside it that the plane sits a few inches higher and you need a higher step to get in to work on things.
Chris Moon
Leesburg, VA
RV-14A kit # 140243
VAF 2017 and 2018 paid
www.mykitlog.com/chrismoon/
Old 08-27-2017, 08:52 AM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Default Bogert Tow Bars
Bogert sells a kit of peg extenders for RV A-model nose gear:
https://bogertaviation.com/products/rva-tow-pin-kit
With that, their RVA tow bars have extended tubes that extend well over these pegs and into the nose wheel fairing.
On their website, type "RVA" into the search window, or give 'em a call.
Scroll
Sid "Scroll" Mayeux, Col, USAF (ret)
Northwest Regional, Roanoke TX (52F...home of DR's Van Cave)
"KELLI GIRL" N260KM RV-7A tipper, YIO-360M1B, dual SkyView, GTN-650, VPX, EarthX LiFePO.
Wrap by AircraftWraps.Com. Nose Art by VictoryGirl.com.
90% done, 90% to go...
www.mykitlog.com/scrollf4/
Proud and grateful 2018 -=VAF=- Contributor
Old 08-27-2017, 09:27 AM
Tony_T's Avatar
Tony_T Tony_T is offline
Van's tow pin setup consisting of bolts and a washer stack works well, does not loosen and is way less expensive. The parts come with the wheel fairing kit on the 12 and may also be included with the 14 fairings.
Tony
RV-12 #202 -- Flying
Old 08-27-2017, 12:23 PM
The RV-14 is just like the RV-10 (uses a reenforced stand-off) but it does work well.
Same (RV-10) tow bar works for both.
Scott McDaniels
Hubbard, Oregon
Old 08-27-2017, 05:13 PM
TimO TimO is offline
Yes, the Bogert RV-10 tow bar works for both the RV-10 and RV-14. I own 2, one for each plane.
Tim Olson - CFI
RV-10 N104CD - Flying 2/2006 - 1300+ hours http://www.MyRV10.com
RV-14 N14YT - Flying 6/2016 - 175+ hours http://www.MyRV14.com
RV-10/14 Transition Training: http://www.RVCFI.com
Old 08-28-2017, 08:42 AM
Thanks for the feedback. I'll be putting in an order for a Bogert.
Craig Wheeler
San Diego, CA
RV-7A Sold
