Old 08-26-2017, 12:33 PM
JDA_BTR JDA_BTR is offline
Default 38-04 rear window
Rear window evenly drilled and tapped. Looking at the fit of the F-01474 stiffener angles and the window extends to the level of the second hole down. The rear flange of the stiffener interferes with the window. Am I better to carefully reduce window width or trim the stiffener to fit? I'm inclined to trim the window.
N1463 seems a good number....
Old 08-26-2017, 03:19 PM
Jake14 Jake14 is offline
I trimmed the window, trying to avoid making any sharp corners.. Seemed to work fine
Old 08-30-2017, 09:13 PM
All is trimmed, holes drilled and countersunk.
What is best practice for the inside-window side of the hole. A few turns with the deburr countersink? Or overthinking it.
I also found a new way to burn my finger today. When countersinking the outside of the window holes the pilot on the countersink gets pretty hot.....
