View Poll Results: RV-9A - Which IO-320 - Which Cowl - Which flow
IO-320 D2A 8 40.00%
IO-320 other (specify) 9 45.00%
SJ Cowl Shorty 0 0%
SJ Cowl Extended forward facing 1 5.00%
SJ Cowl Extended updraft 3 15.00%
SJ Plenum 3 15.00%
VANS Baffles 11 55.00%
Multiple Choice Poll. Voters: 20. You may not vote on this poll
Old 08-25-2017, 08:40 PM
1bigdog 1bigdog is offline
Default RV-9A - Which Engine - Which Cowl
I can't think of a better way to do this other than a survey. I'm not looking for a debate. I'm no expert on the many varied engine variants of the IO-320 and I want to place my order for the finish kit next week. I'd like to use the SJ Cowl but between updraft, forward facing, sump position, prop extensions it's a bit cumbersome so I'd like to know what has actually worked in practice for others.
My 9a will have an IO-320 with a 3 blade Catto prop and I have no intentions of changing to constant speed.
I'll need a vacuum pad for a gear driven backup alternator (don't know if all engine variants have the vacuum pad).
So the questions whittle down to
Which specific IO-320 variant did you choose? D2A, D1A, other ?
Which Sam James Cowl? Shorty, extended updraft, forward facing?
Did you use the SJ plenum or VANS baffles ?
Greatly appreciate the input.
Michael B.
C-FWMB (reserved)
College Fund Contributor
Old 08-25-2017, 08:53 PM
dwranda dwranda is offline
Can't wait for some responses! Very interested as well!
9A in progress
Working on fuse
Finish kit arrived!!
Mattituck TMXIO-360 red gold
Dues paid Dec 17
Old 08-25-2017, 09:22 PM
qtrmiledan qtrmiledan is offline
Default Cowl choices
O320 D3G converted to IO320, vans baffles with home brew plenum, James extended cowl, was carbed, so it's updraft. Used James air filter kit.
Danny B
Baker,La.
RV9A #91137 Flying!!
Old 08-25-2017, 11:59 PM
RicoB RicoB is offline
O-320 E2D not sure what cowl yet
Rico Burgos
RV9a - Building, Based at KWHP (CA)
C-150 Based at KMOD
VAF Paid 2018
Old 08-26-2017, 08:24 AM
gfb gfb is offline
Titan IO-340, used the vans baffles/cowl but would happily try the SJ option next time.
RV-9A - Emp, Wing, Fuse, Finish, Electrical, Avionics FW FWD complete, Finishing up...; started 01/2015.
Old 08-26-2017, 08:42 AM
KRviator's Avatar
KRviator KRviator is offline
Same here, but using the O-340. Vans Cowl & Baffles.
Only hiccup was the Rotec TBI I used is slightly shorter than the traditional carb so I had to make my own FAB. If I were doing it again, I would go with EFI and the snorkle-less cowl, with a basic cone-type filter, but the Rotec starts easily and I'm quite happy with it!
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A 19-8519 - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Phase I done. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 08-28-2017, 06:43 AM
Neal Trombley Neal Trombley is offline
Not that far along yet, but I think by OSH 18 I will be..
My guess IO320 with CS and 3 blade
My goal is economy and smoothness
Not sure of Cowl
Sam I see every pancake breakfast at our EAA66... I guess I should look into them
Neal Trombley
SW Florida
EAA 66
N517NC ( reserved)
Dues Paid
NOV 2016
July 2017
Dec 2017
Old 08-28-2017, 08:09 AM
Alex_K Alex_K is offline
I have Titan IOX340 with normal Vans baffles and cowl.
Alexander Kochetov
RV-9A
Flying
Old 09-22-2017, 08:18 AM
Default Thanks
So first, thanks for the responses and the inspirational photo.
What I really learned is that my learning curve was nowhere near complete. I thought I had asked an easy set of questions.
What I can extrapolate is that most purchased the VANs cowl and appear to be using vertical draft and and the VANS baffle. Given my home base and where/how I intend to fly it became clear the vertical sump gives what is needed for heat muffs (something I never considered when I first asked the question).
Cheers.
Michael B.
Michael B.
C-FWMB (reserved)
Old 09-22-2017, 03:34 PM
Default 2 up fully loaded out west
2 up fully loaded out west I would have used an extra 20 HP.
