Old 08-26-2017, 07:52 AM
tomkk's Avatar
tomkk tomkk is offline
I thought about adding a cooling fan as well but didn't see a convenient way to mount it without it sticking out in the way. Where did you mount it?
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845
First flight 06/10/2015
Old 08-26-2017, 10:35 AM
todehnal todehnal is offline
Originally Posted by tomkk View Post
It looks like the "Country" section of the mailing address only contains EU countries. Are you sure they'll ship to the U.S.? It also looks like the credit card info only provided for DE or EU credit cards.
Thanks Tom. I didn't notice that and have not yet placed my order. Since I have already made email contact with them, I went ahead and sent a reply, asking those questions. I probably won't hear anything until Monday, but I will post the reply. Thanks again...........Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 08-26-2017, 11:06 AM
tomkk's Avatar
I'd be interested in the answers, also what the shipping cost might be ...
Tom
Port Orange, Fl
Old 08-26-2017, 01:39 PM
Dave12 Dave12 is offline
I've been using a John Deere clone for 150 hours now. The first one lasted 50 hrs. The second one with a small cooling fan mounted just on top of the fins has been going for 100 hrs. now. I like the charge rate. I think this has proven that heat is the killer. They need airflow. Now that I have talked about it, it will probably blow tomorrow.
Wag Aero Sport Trainer
N588DF RV12 #336 Sold
N73DF RV12 #244 Flying
Old 08-28-2017, 01:37 AM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
In January 2017 I ordered 14 Silent Hektik regulators. Initial price 197,-. "Bulk" price 160,-
So my advice is to make a group to buy more regulators at the same time.
Besides that in my installation I needed an extra ground wire from the battery to the case of the Silent Hektik. Without the groundwire my Icom radio "freezes" up.
PH-BZT
MyKitlog
Picasa pictures
Old 08-28-2017, 05:13 AM
I did get an answer from S.H. You suspicions are now verified. I received a reply from my last email, and was informed that they only sell in Europe. So, unless we can come up with a friend or agent in Europe to make the buy and forward the VRs, we're out of luck. At this point I'm open to suggestions....Tom
Old 03-16-2018, 01:54 PM
bob1393 bob1393 is offline
Ramrod25 - Can you tell us with the new NAPA VR how to wire it? There are 5 prongs on the NAPA and 6 on Ducati - but one is not used. The nomenclature on the NAPA VR is not the quite the same as the Ducati - so we are not sure what wire goes where.
We are on our 4th Ducati VR in 2.5 years. 1st one failed at 233 hours, 2nd one at 111hours, 3rd one at 109 hours, and just installed 4th today. We need to try something different.
Bob1393
E-Mail : jpobob@gmail.com if you want to E-Mail me or use PM or even right here in the open forums.
Thanks R25
Old 03-16-2018, 03:52 PM
See...http://www.vansairforce.com/communit...0&postcount=52
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 333
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 03-16-2018, 11:08 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
I ordered both the fix charge rate and stepped charge rate SH regulators. Currently have fix charge rate one installed...has been rock solid; and is a quality product...well worth the expense.
Just installed the EarthX battery...the difference in weight is unbelievable. Going to need some more weight reduction to get to flight level 60 (class A airspace)😎
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 03-17-2018, 09:28 PM
AJSWA AJSWA is offline
Default Which S/H reg?
Hi Ric,
Re - I ordered both the fix charge rate and stepped charge rate SH regulators. Currently have fix charge rate one installed...has been rock solid; and is a quality product...well worth the expense.
- I believe the step rate regulator is the correct regulator for the EarthX Lipo battery, not the fixed charge rate (as you referred to above)
Have you added the wire for the BMS (Battery Management system) and configured the additional Skyview widget? (and Possibly alarm settings for the new BMS screen widget) in my experience with the S/H Stepped charge Reg and EarthX battery change out, i had to disable the audible alarm parameters i had setup in the first instance.
I kept on getting the warning cry "Engine monitor" warning every 5 seconds due to the "high current charging" monitor function of the BMS. (This was due to completing a Skyview nav software updates and BMS widget install and settings and not recharging battery prior to flight.)
If you have just wired up the BMS to a dash visual warning light it's a good idea to have a good read of the meaning of the warning light "flash codes" prior to flying as it can be a bit disconcerting if / when it starts flashing and you don't know what it means. (Yes, i read that part of the instructions later, not before. That's normal isn't it? )
I also had to amend /adjust the "voltage" widget warning parameters to lower values so the initial charge voltage indications for the first couple of charge steps (about 20 mins from memory) were not in the yellow caution range.
Did you add an additional Capacitor to the regulator circuit?
(I noticed this has been discussed previously on another thread and i think it was Scott or Joe that mentioned there was already a capacitor in the AV5000 control module although i don't recall if the capacitor value was mentioned)
Re - Just installed the EarthX battery...the difference in weight is unbelievable.
Odyssey = 6.5 kg, EarthX = 1.9 kg, Difference of 4.6 KG! (10.12lbs)
- I'm confident you made the allowances for the significant weight change in your C/G calculations when loading the aircraft prior to flight.
I'm also guessing you may not have finished the battery instal and started the engine, when you posted the message, as you made no mention of the difference the EarthX makes to the engine cranking speed. In my case the increase cranking speed was significant. i suspect our odyssey battery was in the process of dying, we were having trouble with the occasional engine kick back on startup.
(our engine doesn't have the soft start modules.) I also changed to the later model, increased retard flywheel as well, but did not change the ignition modules @$1,500.00 ea Aus) to help prevent the starting kickback and the associated possible damage to the starter sprag clutch .
Had i installed the EarthX battery first, in most cases, i suspect the increased cranking speed would have alleviated the starting kickback.
So far I have just over 2 hours of engine run and flight time on this new combination. Once i get the Stabilator refitted after finishing of Sb18-02-02 and Sb18-02-03 (next weekend weather gods allowing) i plan to get some more flying enjoyment and experience on the combination.
Andrew
RV 120573
