Old 08-25-2017, 08:07 AM
WingedFrog's Avatar
WingedFrog WingedFrog is offline
Originally Posted by RFSchaller View Post
I'm not familiar with the earthx battery. Is it a Li ion battery? How much weight does it save? How expensive is it? Is it a drop n replacement for the Concorde lead acid battery?
Rich
See this on earthx web site:
http://earthxbatteries.com/earthx-inc-proud-add-vans-aircraft-oems-using-earthx-lithium-battery-new-rotax-912is-equipped-rv-12is
FYI there are several models ranging from $129 to $725... and don't hold your breath about VANs choice!
Builder's name: Jean-Pierre Bernoux
Sport Pilot
Kit # 120395 N124BX
Flying as of 9/11/2013
Builder's Blog:http://vieilleburette.blogspot.com/
EAA 1114
Old 08-25-2017, 09:33 AM
Originally Posted by Jim T View Post
This part of Scott's post really caught my eye. As a builder of one of the old outdated RV-12 kits, I'll be anxious to see what the "Gen 2 kit for ULS installation" will consist of.
Jim
By Gen 2 kit I meant the updated RV-12iS kit. From this point on all new fuselage kit deliveries (once they begin in October) will be the new version fuselage, but builders will still be able to opt for using the ULS engine if they choose. Even if they use the ULS engine the standard kit will still include the Earthx battery.
The actual installation of the ULS engine will largely be the same as the iS... it will use the same cowl with the fwd mounted heat exchangers, etc.
Scott McDaniels
Hubbard, Oregon
Old 08-25-2017, 02:39 PM
Jim T Jim T is offline
OK got it Scott. Makes sense. Thanks.
Jim
RV-12 kit no.: 120647
Working on finish kit
http://www.mykitlog.com/JimT
2006 Rans S-6S Coyote (flying)
Old 08-26-2017, 08:53 PM
engineerofsorts's Avatar
engineerofsorts engineerofsorts is offline
Default EarthX battery on current RV-12
Having done a good "scratch and sniff" on the RV-12iS at Oshkosh, I came away very impressed with the refinements.
Also, having hefted the normal battery and an EarthX battery, I came away lusting after the potential weight savings if I could plunk one of those into my now-"classic" RV-12. Since the batteries are not physically identical (EarthX battery's terminals are in different positions than the 680) a bit of massage of the battery holder would be needed. However, CG-wise, the lighter battery forward of the CG seems like it it would have the effect of lessening the max luggage capacity aft of the CG. Ten cuss words if my analysis is correct.
Comments, Scott?
Rob Reese
RV-12 #332
N73HR Now flying!
Austin, TX
Old 08-27-2017, 06:38 AM
joedallas's Avatar
joedallas joedallas is offline
Default W&B
I don't think you can answer this question without knowing the optional equipment in the front of the CG and the weight of the pilot and copilot
Do a W&B to get your answer ( deduct the weight and arm difference from the old battery )
Also remember the arm of the baggage is somewhat under your control.
Note:
When the fore-aft center of gravity (CG) is out of range serious aircraft control problems occur. The fore-aft CG affects longitudinal stability of the aircraft, with the stability increasing as the CG moves forward, and stability decreasing as the CG moves aft. With a forward CG position, although the stability of the aircraft increases, the elevator control authority is reduced. This can cause a serious condition during the landing flare.
From
https://en.wikipedia.org/wiki/Center...of_an_aircraft
A good read
My View
Joe Dallas
Comments, Scott?
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
