Old 08-23-2017, 08:31 AM
dave4754's Avatar
dave4754 dave4754 is offline
Default Baffles in RV 7 0-320-B2C conical mount
Hello folks
I am installing my baffles and found that the Vans kit accomodates Dynafocal mounts and my Conical mounts wont let the rear bulkhead sit flush with the engine.
Vans say that i need to modify and wondered if any of you have done this and what tools you needed to do it with. I have Dremel, die grinder, files etc.
Thanks in advance for any and all help
Dave Cobb
=VAF=2018 Donation - and a bit extra for great work!
Empennage RV 7 - Tipper
Wings complete
Fuse nearing completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
Old 08-23-2017, 09:53 AM
Zero4Zulu Zero4Zulu is offline
Dave, I just finished fitting the rear wall of the baffles to my Conical mount. I made a cardboard template to replicate the aluminum and trimmed it until the cardboard fit the way I liked it. Basically I ended up with large slots in the baffle that slide in over the rubber Conical mount bushings.
I used my band saw for rough cuts and refined the shape with the die grinder and files.
Steve S.
Rebuilding RV6A
Scio, OR
EAA Ch. 292
Old 08-23-2017, 10:31 AM
dave4754's Avatar
Default Thanks Steve
Sounds like a plan.
Dave Cobb
Wings complete
