Old 08-22-2017, 07:43 PM
upperdeck upperdeck is offline
Default Fired Up the Panel - G3X
So today was a bit of a milestone, I fired up the panel. I haven't bothered to set anything up yet, and the can bus isn't entirely wired since the roll servo/wings aren't installed.
Old 08-22-2017, 09:42 PM
gfb gfb is offline
Looking good! What is the round LED dial next to your G5?
RV-9A - Emp, Wing, Fuse, Finish, Electrical, Avionics FW FWD complete, Finishing up...; started 01/2015.
Old 08-22-2017, 09:46 PM
Thanks! The round dial is an O2 sensor that EFII recommends. It's actually a digital readout that puts a numerical value on the mixture setting.
Old 08-23-2017, 04:58 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
That does look great!
Don't forget that you can power up each display with the Direct-To button pushed and put them into demo mode if you want to take a picture with all the failed indications gone.
While you are in demo mode, you can put in a flight plan, touch the airspeed tape to give it airspeed, engage the autopilot, and "fly" to a destination at any altitude while learning to use the autopilot including coupled VNAV descents.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 08-23-2017, 08:27 AM
dave4754's Avatar
dave4754 dave4754 is offline
Default Looks great!
I am about to do the same and cant wait to see the (new to me) Dynon panel and what it can do.
Thanks for post.
Dave Cobb
=VAF=2018 Donation - and a bit extra for great work!
Empennage RV 7 - Tipper
Wings complete
Fuse nearing completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
Old 08-24-2017, 06:29 AM
jcarne's Avatar
jcarne jcarne is offline
Man that looks awesome! Very professional look to it.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Working on Fuselage
Finish kit on order
Exempt but gladly paying!
Old 08-24-2017, 06:50 AM
pilot2512 pilot2512 is online now
Slider or tip up?
Jay
RV-9A
Empennage complete.
Wings complete.
Fuselage in progress
Wiring in progress
2018 Donation made!
Old 08-24-2017, 07:38 AM
Thanks for the encouraging comments. It's a tip up.
Old 08-24-2017, 09:52 AM
Bluelabel's Avatar
Bluelabel Bluelabel is offline
Hopefully you got the newer version of the PLX AFR (Air/Fuel Ratio) sensor. I need to update mine. I'm stuck using the older Bosch sensors, which don't last very long with leaded fuel. Pretty much every oil change, I can count on replacing that sensor.
Although, I will say, once you get the EFII system dialed, the AFR info becomes less important because you'll know where it is based off your fuel flow anyway. It's amazing what just .3 gph can change on the AFR.
Panel looks sick! The 650 combined with the G3X is glorious. It's like cheating
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Lead on the
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system
"so I got that going for me... which is nice."
2017 Dues Paid"
Old 08-24-2017, 01:15 PM
Hopefully I have the newer version of the PLX then! I'm not sure how to determine that though?
