Old 08-22-2017, 10:53 AM
Cth6 Cth6 is offline
Default RV-12 W&B
Looking at a flying RV-12, D-180 with all the options circa 2010. The Empty Arm seems extremely far aft. 764# @ 83.77". The arm for the nose wheel is 32.25" and the mains are 93.75"
We are almost 1" aft CG with my wife and I with full fuel and 50 lbs of baggage and still 100# under gross. If I want to fly solo I need to be down to 13 gallons with 5# of baggage.
Has anyone updated their Arm in the CG calcs for moving the seat forward? The benefit of being a short.
CT
Dreaming about an RV
Orlando, Florida (FA83, X04, ORL)
Old 08-22-2017, 11:41 AM
If you are serious, consider having the airplane reweighed and the W&B recalculated.
Unless there is something quite non standard about this particular RV-12, what you are seeing is not typical.
Scott McDaniels
Hubbard, Oregon
Old 08-22-2017, 11:53 AM
The arm for your nose wheel is 2 inches aft of mine, which is 30.25
Joe Gores
RV-12 Flying
Old 08-22-2017, 12:04 PM
Download THIS Excel spreadsheet and enter your weights into the yellow cells. Make changes to the yellow cells ONLY.
HERE is a link to a previous weight and balance thread. Read my post #15 in that thread.
Joe Gores
RV-12 Flying
Old 08-22-2017, 12:53 PM
I believe you have an error in your spreadsheet. Empty weight on the Weight and Balance tab is fixed and I believe it should be the sum of the three weights above it.
Good news, after making the cell update, it supports my calcs. BTW, great job on the spreadsheet. Much nicer that what I pulled together.
CT
Old 08-22-2017, 01:03 PM
Really nothing that I have seen is non-standard. No, I have not pulled access covers yet but nothing sticks out. Still haven't had the pre-buy yet.
Definitely will get it done in the pre-buy.
CT
Old 08-22-2017, 04:23 PM
I can not take credit for the spreadsheet. I believe that Walter Tondu made it for his RV-7A. I did modify it for the RV-12. If you have not already, change cell B8 to "=sum(B5+B6+B7)" without the quotes.
Joe Gores
RV-12 Flying
Old 08-22-2017, 08:51 PM
Exactly what I did. Thanks for sharing it.
CT
