Old 08-22-2017, 09:55 AM
Carl Froehlich's Avatar
Originally Posted by Xlr84fun View Post
Aren't they one and the same? I thought the exhaust that Van's sells were manufactured by Vetterman. That was the deal when I ordered mine for the RV-7 w/ -M1B anyway. Perhaps the RV-8 is different.
They used to be, but I believe Van's has a new supplier.
Old 08-22-2017, 10:23 AM
Brantel's Avatar
Brantel Brantel is offline
If that is true.....for shame for shame for shame!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 08-22-2017, 10:38 AM
William Slaughter's Avatar
William Slaughter William Slaughter is offline
AWI 4 into 1 (with a turned down tip, of course)
William Slaughter
Houston, TX
RV-8QB FF complete, baggage door done. Fiberglass work mostly done. Now at the airport for final assembly.
Old 08-22-2017, 11:57 AM
grubbat's Avatar
grubbat grubbat is offline
Default Vetterman
I've got Vetterman Trombone and happy.
Craig
RV-3 Sold
RV-6a Sold
RV-9 IO-360 CS, Flying
1967 Twin Comanche C/R, Flying......
Old 08-22-2017, 12:08 PM
Raymo's Avatar
Raymo Raymo is offline
Ditto on the trombone exhaust. Perfect if running the cold air sump. I am not yet, but plan to do so.
EDIT: Almost perfect. I had to put a small bubble in my James cowl to clear the left side tail pipe clamp.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 08-22-2017, 03:57 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Default Sky Dynamics
I have a Sky Dynamics, 4-into-1 exhaust with the downturned tip. This is on a RV-8 with a parallel valve IO-360-A1A with 10:1 high compression pistons and LASAR electronic ignition system. The exhaust system has over 2,000 hours and it has been very robust. I did have to have the 4-into-1 collector fixed once.
When I replace my engine, I'll probably go with Sky Dynamics again, given my good experience with their exhaust.
Carl N.
Arlington, WA (KAWO)
RV-8, 250 Tach Hours
(Pic)
- Out with the Old, In with the New (Pic)
RV-8, 1938 Tach Hours
(Pic 1), (Pic 2), (Pic 3) - Sold
Glasflügel H-201B Standard Libelle, N564NS - Sold
Rolladen-Schneider LS1-f, N61MP - No longer owned
Old 08-22-2017, 06:40 PM
DanH's Avatar
DanH DanH is offline
Originally Posted by RV8JD View Post
I have a Sky Dynamics, 4-into-1 exhaust with the downturned tip.... The exhaust system has over 2,000 hours and it has been very robust. I did have to have the 4-into-1 collector fixed once.
I'd recommend a 4 into 1, either Sky Dynamics or AWI, just because the tailpipe is arranged for a clean cooling exit...and there is no crossover to heat the fuel controller.
Read what Dave Anders has to say in the October issue of Kitplanes.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-22-2017, 07:06 PM
Van's not very new supplier is Van's. Been making systems in house for quite a few years now.
The systems for the RV-12, 14 and the common crossover system that will work on vertical induction 320's and 360's are produced in house.
I think I am correct in saying that anything else (540, angle valve 4 into 2, etc) that Van's sells is still produced by Vetterman.
Scott McDaniels
Hubbard, Oregon
