Old 08-21-2017, 02:42 PM
f1rocket's Avatar
f1rocket f1rocket is offline
Originally Posted by Tony_T View Post
Terry,
I don't doubt the manual pages that you quote, although I can't find them in either the User Guide or Installation Guide. I'm sure some compromises are done when both terrain and weather are shown, but I wouldn't say that the terrain washes out when weather is enabled.
I agree. I always flew with both enabled all the time.
Randy Pflanzer
Martinsville, IN (II87)
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 08-22-2017, 02:30 AM
dbhill916 dbhill916 is offline
WEATHER should be an option on the LAYERS menu as well as TERRAIN. ...... but WEATHER should an option if the ADSB 470 is working properly.
On the map, ADSB status will show NEXRAD wx status in the bottom left corner and ADSB traffic in the right bottom corner. The transponder can show TIS traffic and TIS would show in the bottom right corner if ADSB is not working. The traffic you see could be just TIS and not ADSB.
Tony, thanks for 2 tidbits of useful info. I now believe that the 470 is not functioning properly. I've never seen the ADS-B or NEXRAD databoxes, only a TIS OK display in the bottom right. I'll see if I can find any info on debugging the 470, or maybe buying the newer 472.
thanks,
-dbh
David B. Hill
N76012
RV-12 #0760
http://n76012.blogspot.com
Dues paid through 6-2019
Old 08-22-2017, 08:30 AM
Tony_T's Avatar
Tony_T Tony_T is offline
I would hold off on the 472. That box has issues that Dynon is working on and, in fact, I don't think they are shipping it anyway right now.
Is it possible you have not configured a serial port for the 470? Van's default software loaded on the SV does not include a serial port setup for the ADSB 470 and you have to do it. Here's how:
Pick a serial port not occupied. The 470 should appear as an option, choose it and it should configure. Mine is on serial port 2:
Hopefully, this will get it working. If not, check the d-sub connections for pushed pins, etc.
Tony
RV-12 #202 -- Flying
Old 08-25-2017, 04:03 PM
Default identified my assumption
looks like several of you identified the issue. I was indeed assuming that TIS data came in the ADSB path, so it "had to be working." Now I know that TIS is via the transponder and I've had no ADSB at all. I'll get out there tomorrow (fingers crossed) and see about setting the serial port. Stay tuned.
David B. Hill
N76012
RV-12 #0760
Old 08-26-2017, 06:46 AM
John-G John-G is offline
David,
My first ADSB-470 box did not work either. When looking at the settings for Port 2 (or whatever port yours is attached to) you should be seeing BOTH the Rx and Tx counters increment … mine were not. If I remember correctly, the Tx counter would increment but the Rx counter did not.
To help isolate the problem to the 470 box Dynon had me pull the connector off the back of the 470 box and loop the two serial pins for Rx and Tx to one another. Next the serial port device was temporarily changed from ADSB-470 to NMEA. After making the loop back and changing the port device to NMEA you should see the Tx and Rx counters increment …. this is because as the port is polled, the transmit data packet is looped back to the receive on the SkyView. If both counters do increment, then the serial port hardware on the SkyView is good and the issue is either the power wiring to the ASDB-470 or the box itself.
John
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2019
Old 08-27-2017, 06:56 AM
Thumbs up RTFM
Yep. As is so often the case with this airplane, if something's not right, just go back and read the friendly manual again. I had neglected to configure Port 2 to ADSB-470 due to my mistaken assumption that the presence of TIS data implied that that had already been done with the factory preset file. I did the configuration and Viola!I have weather and radar data. (Not that I do any RV-12 flying if the weather isn't severe VMC).
Thanks to all who contributed,
-dbh
David B. Hill
N76012
RV-12 #0760
Old 08-27-2017, 08:54 AM
Tony_T's Avatar
Thanks for the feedback! It's good to report what worked; it could be helpful to someone else who has the problem.
Tony
