Old 08-19-2017, 12:35 PM
wjb's Avatar
wjb wjb is offline
Originally Posted by sglynn View Post
Bill
Where do you plan to put the connectors? If inside the fuselage how will you get them in there? Will you drill a fairly large hole? Or put connector bodies on after running wires inside?
Hi Steve,
I was planning on mounting them to the fuse just aft of the aileron pushrod hole.
The DT/DTM connectors have a nice clip that I'll pop-rivet in place. The wing wire bundle will connect to the ones on the fuse. One wing will have two sets of connectors, (1) lighting, (2) roll servo.; the other side just one for lighting/pitot.
Bill Bencze
N430WB (reserved) RV-7 #74152, tip-up. Engine is in the house!
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2018 donation happily made
Old 08-19-2017, 06:15 PM
brad walton brad walton is offline
I used a Cannon connector. Nice clean and solid. But in retrospect Tom Martin's suggestion looks like a good solution if/when the wings come off. Mine have never been off since final assembly.
Old 08-19-2017, 06:26 PM
ty1295 ty1295 is offline
Did this on mine, bought a weatherpak kit for cars that is designed for weather, water, etc. Bit spendy to get the kit and proper tools, but came out nice and I can easily pull the pins out if I need to get thru a grommet, etc.
Jeff Scott
Proud to have flown with P. Wagstaff and some odd Russian.
RV9A #91247/#91434
Old 08-19-2017, 06:46 PM
RV7ator RV7ator is offline
The first place to look for an electrical problem is at the circuit connections. By adding three connections (each contact and contact-to-contact) you've increased failure potential, let alone complexity, and to what good? I ran unbroken wires from the panel/fuses to the wing accessories with little trouble. A few wires and some coax (ah, yes, .3db loss per connector!) will be the very least of my worries if I have to pull a wing. And that's never happened, and never will unless something really nasty happens. The only time someone might want to pull wings is paint after test flights. In that case, pulling the wires takes less time than the installation of a fuse/wing connector.
John Siebold
Old 08-20-2017, 08:10 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Connectors
This has been done many ways obviously. Some with connectors, some without. I had connectors on my first RV and installed connectors on the new one. It's a little more work up front but really worth it when it comes time to remove the wings for paint or any other reason. I also have the same type of connectors for the wing tips. Super easy. You can also see the BNC for an antenna. There are two of these on the other wing.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N707EE-Building
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 08-20-2017, 08:16 AM
RV7Guy's Avatar
Default Second photo
Here's the second one.
[IMG][IMG][/IMG][/IMG]
Darwin N. Barrie
Chandler AZ
www.JDair.com
EMS Bell 407,
Old 08-20-2017, 10:41 AM
Lars Lars is offline
Default underseat terminal block
Here's a photo from my RV-7 build if it helps. I've done a couple of RV's this way now. As Steve mentioned, I found that it simplified the wiring. They are under my butt, in the bay next to the center tunnel. Crotch belt mount is visible at center left for orientation purposes.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
600 hours as of April 9, 2018
Old 08-20-2017, 01:54 PM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
Lars, do you have the terminal blocks seated on a tray?
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
rvblog.thebrices.com
Old 08-21-2017, 08:33 AM
airguy's Avatar
airguy airguy is offline
I installed DB9 connectors at the wing root to match DB9 in the wing, but I would not do it again. The time spent versus the likelihood of needing them just doesn't make sense to me (now after the fact).
Greg Niehues - VAF 2018 dues paid
Garden City, TX
N16GN flying! http://websites.expercraft.com/airguy/
Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 08-21-2017, 01:20 PM
I used terminal blocks and ring connectors for the position lights/strobes, and just hardwired everything else, leaving a little slack for a future cut & splice. The only time the wings will ever come off is for transport, if I'm ever unlucky enough to have an off-airport landing.
Doug
RV-9A "slider"
Flew to Osh in 2017!
Tail number N427DK
Donation made for 2018
