Old 08-16-2017, 10:45 AM
BoilermakerRV's Avatar
BoilermakerRV BoilermakerRV is offline
Default Fuel System Planning
I've just reached a point in the construction manual where fuel valves and plumbing is beginning to be installed. I am currently planning on a fuel injected system. Most likely the XIO-360-M1B from Van's. Trying to read up on injection and ignition systems, but coming up with more questions than answers. Any help is greatly appreciated!
Per Van's engine order form, "All engines are equipped with roller tappets, dual magnetos, ignition harness, fuel pump, starter, vacuum pump drive, prop governor drive, and carburetor/injector." (emphasis mine) Does this injector require a fuel return?
I'm leaning towards including the e-Mag option as well.
Michael
Danville, IN
RV-7A Fuselage
N317PU Reserved
2017 Dues paid (July 2017)
Old 08-16-2017, 11:05 AM
F1Boss's Avatar
F1Boss F1Boss is offline
Default one suggestion
Might as well put the return line flange on the fuel tank inboard ribs - all else can be done without any difficult mods (plumbing, electric). Plug the flanges if you don't use 'em. Van sells these flanges as 'fuel tank drain flanges'.
BTW Newton makes very good valves - their duplex valves are compact (if you need one).
http://www.newtonsprl.co.uk/
And of course, Ross Farnham supplies a very good fuel system (that uses a return line setup), and an ignition that goes with it if desired.
http://sdsefi.com/cpi.htm
I do not know if you can delete the stock fuel system and mags on your engine order...
Best,
Old 08-16-2017, 11:21 AM
Default Looking Ahead
Thanks Mark. I'm definitely interested in the SDS injection and ignition systems. I may have to upgrade things a little at a time. Start with the Van's stock system and slowly replace as money and time become available.
Michael
Danville, IN
RV-7A Fuselage
N317PU Reserved
Old 08-16-2017, 04:08 PM
Michael, plumbing around a duplex selector valve, whether Newton or Andair will be tight. Suggest you plan accordingly!
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 08-16-2017, 04:43 PM
DanH's Avatar
DanH DanH is offline
The M1B's stock constant flow injection does not need a return line. The single exception would be if you elect to install an (entirely optional) Airflow Performance purge valve, in which case you need a line back to one tank, or to a line feeding from one tank. The purge valve can aid hot starting by allowing the circulation of cool fuel through the system prior to start. No special fuel selector valve is required, with or without the purge valve.
SDS injection does require a return line from the engine compartment to a duplex fuel valve, then return lines from the valve to each tank.
If you elect SDS injection, the sensible choice is SDS ignition. Personal opinion, but with constant flow injection, you should select a stand-alone SDS CPI ignition rather than P-mags, as you get complete control of dual switchable ignition maps, one for best power mixture, and one for LOP operation.
As Mark said, you may wish to install return ports in the tanks while building, as they would be a pain to install later.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-16-2017, 09:51 PM
jcarne's Avatar
jcarne jcarne is offline
I just had to go through the decision of return line or not too. I am most likely going with the stock engine but am putting in the return port on the tank because it is easy to do now. I ordered two of the following:
VA-112 (this is the quick drain fitting that gets riveted on)
AN816-6-2D (this fitting goes from 1/8" pipe thread on VA-112 to 3/8" tube)
AN929-6D (this is a cap for the fittings as I am not planning on installing a return line right off the bat)
Many people run the return line to the second bay but I have seen many people dump into the first bay with no problems what so ever so that is what I am planning.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Working on Fuselage
Finish kit on order
Exempt but gladly paying!
Old 08-17-2017, 10:27 AM
Default Same
I think I have decided to do the same. While my wings are installed for fitting, I'll select a good location for the return port.
Michael
Danville, IN
RV-7A Fuselage
N317PU Reserved
Old 08-17-2017, 11:36 AM
Ralph Inkster Ralph Inkster is offline
While you are at it, don't forget to drill the corresponding hole thru the side of the fuselage for the (maybe) return line, easy to plug off for now with an appropriate sized grommet (center hole sealed with silicone). The fuselage hole would be awkward to drill later with wings/tanks installed.
Ralph
Maintain lots, upgraded & repaired some, modified more, rebuild a few, & built 4 of 'em
Old 08-17-2017, 03:34 PM
Chattin35 Chattin35 is offline
Default Nope
I have that setup (YIO-360-M1B) and did not use a return line. Built per the plans.
