Old 08-15-2017, 09:07 PM
Selma Selma is offline
Default Leaky Carb
After 360 h TT (RV9a, O320 D1A) the gasket of the acceleration pump (Marvel-Schebler MA4SPA 10-5217) got leaky. The airfilter E-3260 has this notch cut out and RTV seal around the acc.pump. I guess vibrations to the acc.pump are the culprit
Does anyone has changed this design? How? I would be very thankful for your help. We are not the builder, bought it flying. Thanks.
Pit
flying RV9a
a father & son project
Old 08-16-2017, 06:13 AM
YellowJacket RV9 YellowJacket RV9 is offline
As seen in another thread today, the notch and RTV in the air filter are normal and per plans. I doubt that would cause vibrations and a leak. I had a similar issue with a leaking carb. I had it overhauled and has been flawless since. (I also had the main jet drilled up one size).
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 08-16-2017, 08:38 AM
The filter installation has no influence on causing a leak on the plunger seal.
This is a common issue on all types of aircraft with carb's that have an accelerator pump.
Scott McDaniels
Hubbard, Oregon
Old 08-20-2017, 04:04 AM
Default Airfilter issues
Chris, Scott,
I thought you might be interested in reading this web page:
http://www.vansairforce.com/communit...ferrerid=13027
From,
Selma
Pit
flying RV9a
