Old 08-14-2017, 09:53 PM
N804RV's Avatar
N804RV N804RV is offline
Default RV-8 QB wings prepunch hole missing?
one prepunch hole missing on inboard hinge bracket double/rear spar. Callout for all inboard hinge bracket to rear spar/doubler is AN470AD4-7. Can find no mention in plans or drawing of special consideration for this particular rivet. Any ideas?
Ken W.
Mount Vernon, WA
2018 VAF Supporter
Old 08-20-2017, 05:56 PM
SgtZim SgtZim is offline
Call Van's support line, they are very good at clearing things up like this. My kit has had a few punched hole errors and they always send me replacement parts quickly. Your "missing " hole should be easy to resolve though.
At this point, I'd suggest also looking at the service bulletin and fix kit for possible cracking at the hinge mounts. I added the reinforcing plate on my right wing because it was still open and easy to do.
RV-8 slow build
IO360-M1B Sensenich fixed pitch
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Facebook "log" https://www.facebook.com/BZsRVproject/
Old 08-20-2017, 06:05 PM
RV6_flyer's Avatar
Default SB 16-03-28
That hole will be drilled in assembly with SB 16-03-28.
Need to ADD SB 16-03-28 parts while you are building. Much easier to install without the skins installed than after flying.
Looks like it is a $10 USD addition.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Building RV-8 S/N: 80012
