Old 08-14-2017, 04:05 PM
JHartline JHartline is offline
Default Anyone using the B&C 700H oil filter adapter on an IO-390?
Or as I describe it, "the one that pokes up above the motor a little bit." If so, are there any issues with clearance on the cowling? Fixin' to mount the motor so I'll be able to figure out the clearance on everything under the hood but not the cowling quite yet. I have the test items from B&C so I can get a pretty good measurement on the height.
I know about the tach cable interference...but I have dual P-mags so no issue there. Also looks like the oil cooler return line is clear as well.
Thank you!!
James Hartline
Carrollton, GA 5GA2
RV-14 - Finish and FWF in progress
T-Bolt IO-390
Maule MX7-180
Old 08-14-2017, 08:02 PM
Default Aaaaand...looks like I answered my own question
Was not expecting to get the engine mounted tonight but my very thoughtful neighbor (A&P) came by and I think it took us ten minutes to get it on the mount. More time to tighten stuff up but that was way faster than I expected.
Gave me time to play with the filter adapter and the standby alternator. It appears everything will fit but probably a specific order for attaching things to ensure I can torque all the nuts properly.
That IO-390 is a looker for sure
James Hartline
Carrollton, GA 5GA2
T-Bolt IO-390
Maule MX7-180
Old 08-17-2017, 02:16 AM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Any chance of posting a few pics?
Rob Lasater
Rv-14 emp/fuse done working on wings and finish
Paid dec 2017
Old 08-17-2017, 03:24 PM
I'll post some pics when I can...I've not got anything mounted and I also want to check all the fuel and oil lines for proper clearance before I declare total victory. So far looks good.
James Hartline
Carrollton, GA 5GA2
T-Bolt IO-390
Maule MX7-180
Old 08-17-2017, 08:26 PM
JDA_BTR JDA_BTR is offline
Awesome. I want to do the exact same thing and there was an earlier thread on it. I'm curious to know what spacer adapters you needed to get because there are a few choices....
N1463 seems a good number....
