Old 08-13-2017, 11:43 AM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Default Rear canopy question
On page 38-03 step 8 says "final drill #27 all holes in the window ". Dumb question but even the drilled and tapped holes that go over the roll bar?
Rob Lasater
Rv-14 emp/fuse done working on wings and finish
Paid dec 2017
Old 08-13-2017, 02:50 PM
I don't have plans at home so I can't say for certain but I think the answer is yes.
The plans have you initially leave the holes in the window under sized for the hole to act as a guide in helping to assure you tap the hole in the roll bar straight.
Once the holes have been tapped, you enlarge the screw holes in the window for a slip fit of the screw (the screw is intended to thread into only the roll bar).
Scott McDaniels
Hubbard, Oregon
Old 08-13-2017, 02:53 PM
Av8rRob's Avatar
Awesome thanks Scott. The diagram does don't indicate that so i wanted to be sure. That would pull the window tighter.
Rob Lasater
Paid dec 2017
Old 08-13-2017, 06:02 PM
Be careful....
The angle of the window only matches the angle of the roll bar across the top.
In other areas there is a slight mismatch and the screws are not intended to be torqued up tight which would put a lot of pre-load on the window at the holes.
That is why clear sealant is specified on the threads... to make sure the screws don't back out.
Scott McDaniels
Hubbard, Oregon
