Old 08-12-2017, 11:18 PM
dave4754 dave4754 is offline
Default Trying to make a Scott Oil Cooler work
Hello Gents and ladies:
I am beginning the install of the baffle to my RV 7 and I want to use a Scott oil cooler that i sourced at auction. It tests good and is an 8 column cooler.
It is apparently larger than the Vans EA - 11 cooler as it does not fit the Vans oil cooler bracket i bought. I dont see why i cant make it work as many have had to add stiffeners to the Vans baffle kit anyway I thought i could do that and make this coole work.
Any thought on why it wont?
Link to pictures on OneDrive are below.
Thanks for all input.
Dave C,.
https://1drv.ms/f/s!Apov9vtfo19vzFVyCptUibn3ZRqz
Dave Cobb
=VAF=2017 Donation - and a bit extra for great work!
Empennage RV 7 - Tipper
Wings complere
Fuse coming along, Canopy looking good!
AME reviewed and repaired O-320-Lyc installed
Old 08-13-2017, 08:02 AM
Default no thoughts on this?
No one have any thoughts on this idea?
Dave Cobb
Wings complere
Old 08-13-2017, 08:19 AM
Tbone's Avatar
Tbone Tbone is offline
Default Difficult
That cooler will be difficult to fit due to the outlet configuration. I have seen it done but due to the outboard outlet and the need to maintain cooler clearance on height of cowling and engine mount it will be tough. I just sold a similar cooler due to those issues.
___________
Terry
RV7
XP IO360
Old 08-13-2017, 09:30 AM
erich weaver's Avatar
erich weaver erich weaver is offline
For me at least, your link requires me to sign in to a Microsoft account, so I am unable to view your pictures.
Erich
Old 08-13-2017, 11:28 AM
RV Jerry RV Jerry is offline
Do yo plan on sending cooler someplace like pacific cooler for o/h prior to install?
Jerry Scott
Rocket II
Old 08-13-2017, 01:21 PM
Dave, you can. BUT, you'll have to space the cooler out from the baffle enough for the block fitting to clear with whatever AN fitting you are using. You might consider sending it to Pacific Oil Cooler, have them clean and test it, and change that block to a MALE AN, or more simply, convert the ends to the Vans Cooler configuration.
It may not be cost effective to do so, against buying the cooler outright from Pacific.
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 08-14-2017, 10:07 PM
Default Thanks
I have contacted my trusty folks at Alberta Aero and they inform me that they can and will test the cooler prior to install.
|I am a little confused and concerned on TS comments but so far I have the baffle installed on the engine and all looks good so once the cooler is tested I think I will go ahead if it tests good and use it. The fittings seem to be ok but i will install the cowling to make sure that all tucks in nicely.
Thanks to those that responded.
Dave Cobb
Wings complere
Old 08-15-2017, 06:38 AM
Dave--looks like the block fitting will hit the baffle especially with an AN Adapter on it.
Ridgeland, SC
