Old 08-06-2017, 08:57 PM
N478RV N478RV is offline
Default Canopy crack
Anyone have any experience repairing a canopy crack? I have an RV-8 with a 4" crack behind the passenger seat. It's been stop drilled and has flow for over 2 years as is. I'm outside of Orlando Florida. Thanks!
Old 08-07-2017, 07:32 AM
bkervaski's Avatar
Do you have any pics?
Progress: First Flight Prep
Old 08-07-2017, 08:35 AM
spatsch spatsch is offline
I used this approach:
https://www.polyvance.com/pfxcanopy.php-1
Worked fine.
Oliver
Oliver Spatscheck
RV-8 & J-3
N-2EQ & NC-49762
http://www.spatscheck.com/oliver
Old 08-07-2017, 10:58 AM
wilddog wilddog is online now
How is the canopy attached to the frame? Rivets or glue?
Old 08-07-2017, 02:14 PM
74-07 74-07 is offline
Default Canopy repair
My 7 had the usual broken out piece at the right rear corner. Thru a friend, I met a gentleman who had used this same technique to repair an 8 canopy previously. He took my canopy (and the broken piece) and a week later, returned a beautifully repared canopy. The old crack is not visible nor can you feel it. It is also very strong.
Hope this works as well for you.
Old 08-07-2017, 07:47 PM
TJCF16's Avatar
TJCF16 TJCF16 is offline
Lew does fantastic work!!
Tim Crouch
RV-9A N626TC
"Merlin"
Old 08-07-2017, 08:24 PM
Doug94 Doug94 is offline
Default Crack repair
I had a crack in the same spot, 4" and stop drilled. I ran across a product and procedure in this forum that I followed. Right now it's been more than 2 years and no problems.
Product: scigrip #4 and scigrip #16 (both are acrylic bonding cements)
#4 is thin and has a fine plastic tube which is inserted into the crack. Follow up with the thicker #16 then buff. The crack can still be seen but very strong bond.
Good luck
Old 08-14-2017, 09:07 AM
Where is Lew, I would really like to bring my canopy who is experienced instead of trying it myself. thanks!
Old 08-14-2017, 09:10 AM
It's riveted on.
Old 08-14-2017, 02:43 PM
Default Canopy Crack
PM sent please check
