Old 08-05-2017, 06:10 PM
LUKLA LUKLA is offline
Default Dynon Avionics standard pakage.
Folks, I am getting my dynon standerd package from vans this week. Any suggestion before I proceed to install. I am going to have 2 axis auto pilot with panel Knob.
Inputs will be appreciate as always.
Lukla
Old 08-05-2017, 06:41 PM
John-G John-G is offline
Lukla,
I do not remember stumbling across any gotchas during the instillation of the Dynon SkyView, Knobs and associated goodies ... everything is pretty much straight forward. If memory serves me correctly, the Adel clamp adjacent to the left cooling fan was small for the amount of wires going through it, so I used a larger Adel clamp.
I do remember there being an incorrect callout for the trim wiring ... but when using the AP Knobs panel, there is a trim set-up procedure that you will need to run which verifies correct trim movement. The Dynon will make the correction if the trim does not move the correct way ... so it is not a big deal but I wanted it correct to begin with. I did a write up on the Blog prior to discovering the Dynon will make the correction during the trim setup procedure:
http://www.dogaviation.com/2016/03/w...d-in-trim.html
http://www.dogaviation.com/2016/04/c...gs-for-ap.html
If you are planning on eventually going with Wi-Fi, now would be a good time to install it. Suggest going with Dynon's Wi-Fi USB dongle because they have added a little wire pigtail as an antenna for better connectivity to devices in the cockpit such as notepads, phones, etc. Now is a good time to install it because getting all the screws out of the upper forward fuselage skin and instrument panel to add it later is truly a PITA.
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2018
Old 08-05-2017, 07:58 PM
Thanks you John.
I read your blog a lot when I get stuck some time.
Old 08-06-2017, 02:57 PM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
If I was building right now, I'd add the handle for entry as shown in the new 12is. That is where the autopilot controls are in mine so I'd investigate adding the handle and relocating the autopilot controls lower.
Scott- 2018 dues paid
Got medical back, now building a 7A.
RV-12 #120515, 319RV over 200 hours.
1st flight 12/08/15, flew SNF, Oshkosh, Triple Tree & SERFI in year 1!
RV-9A, 536 hours, sold, RV-7 sold, Kitfox sold
Old 08-06-2017, 05:12 PM
AeroDog AeroDog is offline
I can't figure out which handle you're referring to.
Empennage and fuselage kits complete
Wing kit compete, Finish kit nearly complete
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2018
Old 08-06-2017, 05:15 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Cockpit handle on panel to aid entrance and exit.
http://www.vansaircraft.com/public/rv12iS_whats-new.htm
Carl N.
Arlington, WA (KAWO)
RV-8, 250 Tach Hours
(Pic)
- Out with the Old, In with the New (Pic)
RV-8, 1938 Tach Hours
(Pic 1), (Pic 2), (Pic 3) - Sold
Glasflügel H-201B Standard Libelle, N564NS - Sold
Rolladen-Schneider LS1-f, N61MP - No longer owned
Old 08-06-2017, 08:28 PM
N456TS N456TS is offline
FYI, you don't need to buy Dynon's really expensive WiFi adapters.
I use two "Edimax EW-7811Un" in a Dual 7" Skyview setup.
The WiFi adapter are only $8.50 each on Amazon with free prime shipping.
A whole lot lower cost then $70 for two. Plus no USB extension cables needed due to their extremely small design and no reception issues.
Old 08-06-2017, 09:09 PM
Jim T Jim T is offline
Not sure if you could add that handle and keep it ELSA (if that's important), but it could certainly be done later. Maybe even another handle over toward the right side.
Jim
RV-12 kit no.: 120647
Working on finish kit
http://www.mykitlog.com/JimT
2006 Rans S-6S Coyote (flying)
Old 08-10-2017, 06:56 PM
Jim
AP knob goes where handle is. Will figure out somewhere else, thanks
Lukla
Old 08-10-2017, 07:00 PM
Awesome , thanks a lot. I would definitely go with $8.50.
Lukla
