Old 08-05-2017, 01:21 AM
Adriaan Kleyn Adriaan Kleyn is offline
Default RV14 IO390 difficult to start
I struggle to start my RV14 IO390 cold or hot. I can't find a procedure that works consistently every time. With my Cessna 182 with a Lycoming IO 540 it is easy,when cold - throttle full forward, mixture full rich ,prime till you get a positive fuel flow, mixture fully lean, throttle 1/4 inch and crank. It will start immediately. When cold - throttle 1/4 inch, mixture fully lean, crank and catch with the mixture when it fires. It work every time and I have never had a flooded engine. With my IO390 it is very different story, since I've had a flooded engine several times as well as a flat battery. I have tried several different techniques but doesn't get consistent results. I need some advice.
Old 08-05-2017, 06:28 AM
Ron B. Ron B. is offline
I'm certainly no expert , but I find just the opposite with my I0-390 (RV-14A0 and the 0-540 in what use to be our RV-10. Only start issue I've had so far (knock on wood) is trying to re-start for fuel after shutting down for the night and not opening the fuel valve.
I do the same procedure as you but I only advance the mixture after it begins to fire and I only move it forward slowly.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 08-05-2017, 07:28 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Sounds similar to my RV-10 story, IO540
It came from the overhaul shop with retard mags, and no Slickstart -- took about 18 months of dead batteries to figure it out --- installed Slickstart and problem went away.
Ron
RV-10 Co-built (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV)
IO360, 180HP/CS, AFS 5600T, G650, VIZ385
Very Happy Contributor
Based at KCLW (Clearwater, FL)
Old 08-05-2017, 07:39 AM
Super Moderator
I think you are overpriming. I have found it takes very little prime, less than 2 seconds of pump with the throttle only cracked about a quarter.
Try that.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Van's East Coast Representative
www.Baselegaviation.com
Old 08-05-2017, 08:35 AM
Vic, what do you do with the mixture after priming? Do you leave it fully rich or do you catch it when it fires.
Old 08-05-2017, 09:08 AM
BillL BillL is offline
Read this: http://www.vansairforce.com/communit...43&postcount=9
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
2017 Dues Paid
Old 08-05-2017, 01:05 PM
With the first (RV-14A) prototype, we learned after some initial struggles, that the Andair fuel pump is a very high volume flow pump.
Any RV model equipped with the Andair pump will require a change in priming technique from what people have always used / learned.
First start of the day in warmer weather I put throttle and mixture full fwd and run the pump for about 1 second (in mid summer temps even that is sometimes too long). Then set the throttle to about 1/4" open and crank. It should start right up.
In (our pacific north west) cold weather I double the time. In real cold climates you might have to do 3 seconds, but I doubt it will ever require more than that.
For hot starts I use the mixture sweep method with the throttle open about 1/2"
Side tip...... If you do get a start but the engine is stumbling badly Usually because it is heavily rich / over primed, immediately pull the mixture to cut-off. When the engine operation begins to smooth out, push the mixture back in to about the 2/3rds fwd point and adjust the throttle for proper idle.
Scott McDaniels
Hubbard, Oregon
Old 08-05-2017, 02:52 PM
woodmanrog's Avatar
woodmanrog woodmanrog is offline
Default I know your pain
We had the same issues. Here is how we do it.(Lycoming instructions) Cold start: all controls fully forward. Pump on 3 seconds. Mixture at idle cutoff, fully aft. Throttle open 1/2 inch. Advance mixture slowly while turning over engine. Fully advance mixture when engine fires and adjust idle. Hot start- Throttle FULLY forward. Mixture forward, prime 2 seconds. Mixture fully aft to idle/cutoff. LEAVE THROTTLE AT FULLY FORWARD. Turn engine over and DO NOT push in mixture until engine fires. Push mixture forward and QUICKLY retard THROTTLE. Resist temptation to advance the mixture knob until engine fires! Also, just turn engine over only 5-7 seconds at a time. Let system rest about 30 seconds between tries. Our personal final solution is to install Pmags.
Old 08-06-2017, 07:05 AM
Super Moderator
The mixture is in idle cutoff for starting and I move it forward as it catches. Seems to work well so far.
As Scott, mentioned, the pump seems to flow much more fuel than we have been used to. I'm amazed at how little priming is needed.
Vic
Vic Syracuse
Old 08-06-2017, 07:51 AM
DanH's Avatar
DanH DanH is offline
A cranking engine will fire only when the in-cylinder fuel-air ratio is within a narrow range. It's near impossible to figure out a perfect "sweet spot" setting for all conditions and all airplanes.
So, a successful start procedure finds the sweet spot by sweeping fuel-air ratio through a range of mixtures while cranking, moving either from rich to lean, or from lean to rich. At some point in the sweep, one or more cylinders pass through the sweet spot, and it fires.
Think about how to sweep the mixture, experiment with the knobs a bit to accomplish a sweep, and you'll arrive at procedure that works for you.
http://www.vansairforce.com/communit...8&postcount=18
Dan Horton
RV-8 SS
Barrett IO-390
