Old 08-04-2017, 05:15 PM
Flyer2017 Flyer2017 is offline
Default Oxygen tank installation pictures
I bought a 22 cu ft system from Aerox at OSH after reading all the various posts on the pros and cons of MH pulse demand, SkyOx one setting valve, etc. Couldn't justify the added expense at this point. I plan on using two of the Aerox mounting brackets to mount the bottle to the right side baggage compartment. I saw a picture of a bottle mounted there but had questions about the installation. If you have a similar installation, I'd appreciate pictures and details. Did you put in a doubler to support the clamps where they attach? Feel you needed to reinforce the floor (tank weighs 12 pounds full)? Use nutplates instead of the supplied bolts and nuts? Any advice and pictures would be appreciated. Thanks
RV-9A, 0-320, FP Prop, paid 2017
Old 08-04-2017, 08:11 PM
bruceh's Avatar
bruceh bruceh is offline
Check my build log here and the next several photos.
No doubler, no floor reinforcement needed. Nutplates needed only on the lower bracket mount so you can get the flap cover panel in and out. Just make sure the location of the bracket bolts are clear of the flap arm movement area.
Bruce Hill
RV-9A N5771H flown over 500 hours!
2017 VAF donator
EAA Tech Counselor
Old 08-04-2017, 09:33 PM
mine is mounted identically to this. no issues so far, 3 years.
Old 08-04-2017, 10:09 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
Mine is in the same location as Bruce & Steve.
Bruce, where did you get the cylinder tank attachments?
Dan "RoadRunner" Landry
Morphed RV7, N20DL, PNP Pilot
1045+ hours, hit 1000 enroute to Oshkosh
2017 Donation Paid
Old 08-04-2017, 11:03 PM
boom3's Avatar
boom3 boom3 is offline
I have an Avox bottle and thought I would make a temporary mount using stock screw holes to see how I like the location before modifying the flap cover. (The vertical is a piece of relay track.) After the 24 (hobbs hour) Oshkosh trip I love the location, easy to reach and easy to read the gauge. It works so well I think I'm done.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
Old 08-04-2017, 11:48 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default .32 doublers with nut plates
I riveted .32 as a doubler and added nut plates
https://ibb.co/c06M1a
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
flying with more than 1,700 on the hobbs
Race 771
margarita!
Old 08-05-2017, 12:17 AM
bruceh's Avatar
Brackets were from Aircraft Spruce.
Bruce Hill
2017 VAF donator
EAA Tech Counselor
Old 08-05-2017, 07:11 AM
Default Question for you guys?--
With those locations, it seems like it would be alittle tough to turn on the valve while in flight. Is it? Sounds like a dumb question, and you may be turning it on, before you depart, knowing you were going to a higher altitude.
So, what if you were enroute, and needed to turn it on?
Only asking because I was thinking about O2 for my 7 (if I get that far)
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 08-05-2017, 07:34 AM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Tom
As long as you can look and reach over your right shoulder it is a piece of cake. I have mine mounted the same as Bruce, et al. It's probably the most practical location.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
www.mykitlog.com/dbro172/
1968 Mooney M20C - Sold
1956 C-182 - Sold
Old 08-05-2017, 07:56 AM
boom3's Avatar
Tom
It is within easy reaching distance for me in flight with my shoulder straps on. One would think it be easier to reach if it was mounted in the center but it is really awkward to try and reach behind yourself.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
