Old 08-04-2017, 03:05 PM
Bigortho Bigortho is offline
Default RV-14 Vernier Throttle Cable
The RV 12 come with a McFarlane vernier throttle cable, but the RV-14 is shipped with an ACS locking throttle cable which slips, according to pilots flying their finished RV-14ís.
Well Tim Paine of McFarlane has designed a Vernier throttle cable for the RV-14: cost $310. I will install it next week.
McFarlane Aviation, Inc.
696 East 1700 Road
Baldwin City, KS 66006
785-594-2741 Ext 218
785-594-3922 fax
Old 08-04-2017, 03:34 PM
If it does then the throttle would also be slipping (and they don't) on RV-10's, RV-9's, and RV-7's, because they all use the same throttle control design.
I think you are thinking of a couple people saying that their heat control cable slipped (a very different control cable than the one used for the throttle)
Scott McDaniels
Hubbard, Oregon
Old 08-04-2017, 05:47 PM
KeithB KeithB is offline
I think RV-12 throttles had a tendency to slip because of the spring tension on the Bing carbs on Rotax engines - hence the Vernier. I installed a Mcfarlane vernier throttle cable on my RV-14 but purely for its function.
(I have a Superior XP400 engine and for this engine ONLY, I would recommend adding an extra 2" to the cable length over the standard Vans cable length and this engine will also require fabricating a new throttle bracket.)
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, Phase I compl Apr 3, 2017, >180 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 11/2017
