Old 08-03-2017, 07:50 AM
bluskydreamin bluskydreamin is offline
Question Thunderbolt 540 engine options for SDSFI?
For those that purchased a Thunderbolt 540 at OSH, Were you able to deduct the ignitions, FI, mech fuel pump and push rod from the standard build? I know you can't with the standard Lycoming purchase but the Thunderbolt staff at the show made it sound like this was no problem.
Just curious if this is really the case and T-bolt will be as flexible as the other engine builders going forward.
Thanks.
Old 08-03-2017, 07:53 AM
Super Moderator
Yes, for the Thunderbolt engines you can spec it any way you want. When deleting items they will give you a credit.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Van's East Coast Representative
www.Baselegaviation.com
rmartingt's Avatar
rmartingt rmartingt is offline
I'd like to know the answer to this as well...
RV-7ER - fuselage structure in work
There are two kinds of fool in the world. The first says "this is old, and therefore good"; the second says "this is new, and therefore better".
Old 08-03-2017, 07:55 AM
Vic
Thanks for the quick answer Vic! Really appreciate it...
Old 08-03-2017, 11:13 AM
Janekom's Avatar
Janekom Janekom is offline
For someone halfway around the world - what it a Thunderbolt engine please?
Jan Hanekom
South Africa
AP 325, AMO 1256
http://www.rvbits.com
RV10 - ZU-XOX - (Fuselage)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Sold Flying)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2018
Old 08-03-2017, 11:20 AM
RV8JD's Avatar
RV8JD RV8JD is offline
Default Lycoming Thunderbolt Engines
Lycoming Thunderbolt engines:
https://www.lycoming.com/engines/thunderbolt
"Thunderbolt engines are Lycoming's brand of high performance, built-to-order power plants for Experimental aircraft. With Thunderbolt engines, customers get a genuine Lycoming engine that is factory built, factory tested and factory supported - with several popular options of fuel systems, ignition systems, performance enhancements and finishing options. These features come with every Lycoming Thunderbolt engine:
- Balanced rotating system within 0.5 gram (connecting rods, pistons, piston pins)
- Port and polished cylinders
- Customized paint options"
Carl N.
Arlington, WA (KAWO)
RV-8, 240 Tach Hours
(Pic)
- Out with the Old, In with the New (Pic)
RV-8, 1938 Tach Hours
(Pic 1), (Pic 2), (Pic 3) - Sold
Glasflügel H-201B Standard Libelle, N564NS - Sold
Rolladen-Schneider LS1-f, N61MP - No longer owned
Old 08-03-2017, 11:39 AM
henke@mweb.co.za henke@mweb.co.za is offline
Default Thunderbolt 540
Any difference between BPE540 with cold air and thunderbolt apart from bpe using 1st run core?
Regards
Henke
RV 10 builder
Old 08-03-2017, 04:00 PM
RV6_flyer's Avatar
The BPE540 may use best available part(s) that was not manufactured by Lycoming.
All the Lycoming engines will be all new Lycoming parts with a roller cam.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Building RV-8 S/N: 80012
Old 08-03-2017, 11:38 PM
unitink72 unitink72 is online now
Default Cold air
I have thought a cold air induction setup would be nice too, I think it's around a $5k option from BPE. What would our options be for doing cold air induction on a thunderbolt?
Josh T
RV-10 #1750
N67SC reserved
http://n67sc.blogspot.com/
2017 Dues Paid
Old 08-04-2017, 12:59 AM
Default BPE 540
I went with bpe540 partly because of using showplanes cowl and balanced engine ect. Don't know if thunderbolt will fit showplanes cowl. Another major work is to fit airflow aircon compressor. Have to chop the intake plenum away to make compressor fit. Also have to cnc new adapter bracket between fm200 and cold air sump that about 1/2 inch shorter. Bottom of showplanes cowl interfere with intake plenum. All major work but will be nice once done.
Regards
Henke
RV 10 builder
