Closed Thread
Old 08-01-2017, 06:43 PM
foxhound57 foxhound57 is offline
Smile RV8 Stretch - Now DownUnder
RV8s Sports Car and Heavy-Lift Cruiser
Extract from an article by John de Fraine for VansAirforce Net:.
An experimental aircraft is an aircraft that has not yet been fully proven in flight. Often, this implies that new aerospace technologies are being tested on the aircraft.
So here are some further images of the Stretch RV8 build overseen by Innovative Wings of Canada. (See RV8 Newbie for the start of the build on this forum).
The concept of a stretch to the RV8 design was first instigated by Perry McNeil of McNeil Aviation Corp. (Canada and Australia).Perry brought the design modification and concept drawings to Innovative Wings, and their Engineering Team went to work on the redesign and fabrication.
Perry’s eldest daughter Heather is a Degree Qualified Aerospace Mechanical Engineer (who was working with Boeing Australia at the time), and his youngest daughter Kristy is an AME. The Engineering Team at Innovative Wings "meshed" well with the Australian Concept team and an extremely innovative and exciting project developed for the RV8 stretch.
When asked about the concept Perry states "please understand the objective and concept was not all about Speed per se. There are plenty of F1 Rockets and Super RV8’s already in the skies over Northern America and Australia. The requirements for cruising over the Continent of Australia and for this build was the use of advanced design dynamics to improve upon a known entity".
Firstly, the team looked at the stretch that would have minimal effect on handling characteristics. The aim was to keep the C of G centralised. Then they investigated utility design features. Note, that there is a second cargo locker located forward of the cockpit.
The main stretch was to the second control seat (aft) built with independent Rudders, Brakes, Throttle and its own Instrument Panel. Here an additional 20 inches was added making the entire area suitable (and very, very comfortable) for someone well over 6ft tall (183cm) and at least a size 2XX.
Perry’s wife Leigh is also a Pilot, and he and Leigh share the sectors. Leigh is quite petite and fits well into the RV8s front seat.
Perry’s original design was a 40-inch stretch. Cad-Cam modeling proved the feasibility however not the appearance or aesthetics.
The final design was over 36 inches in length and six inches in height. The extra undercarriage height suits the “rough” unimproved airfields that predominates throughout the Australian outback and a change to the tailwheel was also instigated. The aircraft is fitted with a forward micro camera (lens size about the size of one confetti ring) which enables the aircraft to see forward and the Pilot to easily taxi straight ahead on either of the three Garmin Screens.
Being a Builders Assist project, Perry, his charming wife Leigh and youngest daughter Kristy, were hands on throughout every phase of the construction project. Innovative Wings in Canada have been completing innovative Builders Assist and supervisory build programs for over 15 years now and Perry decided this was the team for surveillance of the build.
The full fast-build kit was purchased from an owner for $17,000 in the USA. Innovative Wings located and transported the RV8 kit aircraft from Florida USA to their base at the Springbank Airport in Calgary, Canada. They used a local, highly skilled DAR to complete the final Engineering and requisite design drawings.
Being a proof of concept aircraft the team manufactured complete new full-length longerons and stringers to deal with the stretch and increased MTOW. Therein they had to dismantle the airframe to rebuild the airframe to structural design. Yes, this Rv8 is built as tough as a Boeing!
The Innovative Wings build team then set-about the reconstruction of this popular aircraft to the new and advanced design by McNeil.
The engineering project manager Shane Daly, states "that this RV8s is now longer than a P51T at just over 24ft in length and the height exceeds 6ft". It is powered by a New 215hp Turbo-Normalised Superior Aero-Sport Power Engine (TIO-400) out of Kamloops, Canada and has a suite of Garmin G3X Avionics with full rear controls and separate G3X panel.
Two Garmin 430W and a Garmin GMC 305 Autopilot and 3 GSA 28 “smart” servo units assisting towards its VFR - NVFR - IFR ratings.
The addition of Two Wing Tip Tanks added extra Range so necessary to meet the "tyranny of distance" in outback Australia and a set of Hollow Point Speed brakes assist with descent from the Flight Levels. The aircraft carries O2. Descent is aided by the electric Speed-brakes.
The aircraft is aerobatic maneuver approved and the cruise speed regime is the same or slightly improved over the standard RV8.
MTOW is 2350lb or 1066kg.
A hybrid, the aircraft can holistically be a very comfortable cruiser and “Winnebago” its occupants around Australia with built in seat-warmers for the cool high-level Turbo-Assisted cruise. It certainly has the cargo/baggage capacity and uplift capability. Whilst on other occasions it can morph into a weekend Sports Machine and thrill passengers and spectators alike!
This RV8 was issued its Transport Canada C of A, on 21st December 2016 AND was issued its Australian C of A, on the 21st July 2017. VH-FSX next chapter is an appointment with the Paint Shop!
Safe Flying!
P.S If you are contemplating do something similar yourself and would like to discuss Perry's build, you can contact Perry through this forum or at McNeilAviation1@gmail.com.
Old 08-02-2017, 04:23 AM
tgmillso tgmillso is offline
Interesting project indeed. Was the wing design changed to handle the increase in MTOW, and is the aircraft still capable of two-up aerobatics?
Tom.
Old 08-02-2017, 05:09 AM
Default Yes
Reply by P.M.
Old 08-02-2017, 05:41 AM
rv8bldr's Avatar
rv8bldr rv8bldr is offline
Cool!
I find it odd, though, that the throttle is on the right. Was that a personal preference? Or is there a more technical reason?
RV-8 C-GURV (Flying since Nov 2004) - Sold
Scratch building 4pl Bearhawk
Vice President EAA Chapter 245
Old 08-02-2017, 10:23 AM
BHunt BHunt is offline
I saw the throttle on the right and instantly went tumbleweed
Scooby
Harrumph!!
RV-8 IO-390 N788MT
Old 08-02-2017, 11:05 AM
It looks as if the forebody and thus the prop have been moved forward, probably to get the CG in reason. But this decreases stability - was this taken into account?
Old 08-03-2017, 10:10 AM
A totally wrong assumption on your part!
Old 08-03-2017, 10:20 AM
Originally Posted by rv8bldr View Post
Cool!
Hi Mark
As you are aware, there exists No Protocol where one places the throttle. It is the builders/pilots choice. As I fly Heavy Jets from the Left seat, it suits me to place the Throttle Quadrant on the Right Side (personal preference).
However, one can place the Throttle Quadrant on the Left Side just as easily within the scope and design of the aircraft.
BTW I am an EAA member as well. My Airline slipís Tech Crew in at Long Beach, Ca. Do you know if there is a Chapter near by that I could visit on my layovers please?
Perry
Old 08-03-2017, 12:26 PM
tfriendshuh tfriendshuh is offline
Super cool - thanks for sharing!
Talk to me about canopy - was the tip-up easier/better option to stretch than a slider or was that also personal preference?
thnx
tim
RV-8A N6677F IO360 CS
Dues paid through 2018
Old 08-03-2017, 12:29 PM
rv8bldr's Avatar
Hey Perry
I live almost 4000kms from Long Beach so I have no first hand knowledge, but I think EAA chapter 7 is based there.
I was just curious about the throttle position. Most tandem/stick aircraft and pilots chose throttle on the left, but I completely understand your choice. I'm going the other way soon; I have an -8 with the throttle on the left/stick on the right and am building a 4 seat Bearhawk where the stick will be on the left and the throttle on the right.
I used to fly a Grob 115C with that setup and I found after the first 15 minutes I didn't even notice the difference. Of course, the far majority of RV-6/7/9/10/12/14 drivers don't understand why we are even talking about it
Cheers
Closed Thread
