Old 07-28-2017, 04:00 PM
Stockmanreef Stockmanreef is offline
Default 36-12: How to adjust stick angle?
I had no idea what to search, so I am asking:
I am on 36-12 and I have no idea how to file down the tab to adjust the downward travel of the stick to 13.6 degrees.
I finally got filed for upward travel to the desired target of 23.1 degrees--I think. When I measure the right the side I get 24.15 degrees, while on the left side I get 22.55. So on average I have about 23.1. The right side down is 11.45, while the left side down is 12.85.
I assume that what you really want is the total angle to be 36.7 to 42.6. The total angles about both about 35.5, so I have at least 1.2 degrees more of travel that I need to file on the down side. I would prefer to file that on eat up side, but I assume that that could cause problems with the stick hitting the seat when pulling fully back.
Filing the up was a PITA and so far as taken 3 sessions of filing.
How the heck do you file the downward angle?
Any tips or tricks would be really really appreciated.
thanks
ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14 (serial number 140073)
N73XP (at least that # reserved now)
Old 07-28-2017, 06:46 PM
well I figured out the root cause of the issue. The plans were revised
Control Column forward travel angle 13.6 +3.0 / -0.0 was 11.4 +2-0.
Control Column aft travel angle 23.1 +3.0 / -0.0 was 20.5 +2-0.
The bearing bracket assembly was made for the original angles and not the new angles.
Maybe Vans was supposed to replace the old bearing bracket assembly with new one that more closely match the correct angle.
Because filing forward angle from 11.4 to 13.6 is **** near impossible.
Ken Stockman
Midland, MI
Old 08-05-2017, 12:25 PM
so no one else has run into this issue.
I think that I am up to about 8 hours trying to meet the angles suggested in the plans.
Any suggestions?
other than to buy a Quick build fuselage, which is too late for me.
thanks
ken
Ken Stockman
Midland, MI
Old 08-05-2017, 12:32 PM
control control is offline
Not there yet, but paying attention... Hope someone who has it figured out let us know
RV-14 kit #140138
working on FW forward and finish kit
wings, tail kit and fuselage basically done
Http://magnusrv.blogspot.se
Old 08-05-2017, 01:10 PM
MED MED is offline
I just completed these steps. As you said, filing the upper bracket was fairly easy. However, filing the lower stop was indeed a PITA. The only way I was able to do it, and get the two stops to hit together, was to use thin strips of 100 grit sand paper (~1/4"), threading them around the tube that the bracket hits with the rough side on the stop side. By holding some slight control force against the stop, it was possible to then pull the sandpaper out. This caused the sandpaper to remove a tiny bit of the stop ( I'm guessing about 2 atoms ). Repeat for a long time until the stops hit together. Fortunately, when I got the two stops hitting together, it was within spec. for travel. There is probably an easier way . . .
Old 08-05-2017, 02:00 PM
how is it possible that vans does not provide the correct part here? Or is this just to off set the need to not have to match drill the skins. I think that I would have preferred to match drill all the holes. After they changed the plans, a new part should have been designed and sent to everyone who already had a kit.
I am not bothering with the bottom stop. I am only going to file the top stop util I hit the called for angle between the aft and forward which is 36.7 degrees.
If I have issue with the stick aft of about 26 degrees, then I will just some how change the angle of the sticks (have it rebent).
I am thinking of using a dremel tool, if I can fit it in the area. My concern is that I will then grind too much off with the dremel and really screw things up.
I am super frustrated at this point.
Ken Stockman
Midland, MI
Old 08-05-2017, 02:06 PM
BTW, if you complete section 35 before doing this then you might actually be throwing stuff around the shop. Access is hard enough, but if you put on the panel frame assembly or the F-01468 (panel frame brackets), then it will be a nightmare and you might want to break some thing. Or at least stop and drink a whole bunch of beer.
Ken Stockman
Midland, MI
Old 08-05-2017, 02:29 PM
MED MED is offline
By-the-way, I have a QB fuselage - setting the stops is still required.
MED
140236
N435MD reserved
Old 08-05-2017, 03:30 PM
maybe you will have gotten luck and there is a new part which has the correct angles. Or at least close.
Ken Stockman
Midland, MI
Old 08-05-2017, 07:36 PM
mine were spot on for the original angles of 20.4 and 11.4. Hopefully I am measuring correctly. I am using a digital level and zeroing it out on the top flange.
Ken Stockman
Midland, MI
