Old 07-28-2017, 10:14 AM
joew joew is offline
Default Super Track vs Tip up/Slider mod
While I'm in the finishing portion of my build (about three years now), I'm considering adding mods as opposed to doing them to a completed plane. So far I'm adding a smoke system (hidden tank) and the "almost RV 14" seat mod.
I was going for the award tip up slider when I discovered the super track system. Looks like the purpose for both is cargo access. Is one better or easier to install than the other?
Those who have seem or used both, what do you think? Pros, cons.
I look forward to hearing what you fine folks have to say
Joe
Perpetual Builder
Old 07-28-2017, 11:33 AM
newtech's Avatar
newtech newtech is offline
I can't speak to the tip-up/slider mod but I have Super Track installed and love it. Our EAA Chapter http://eaa21.org hosts a monthly First Saturday Fly-In and I bring the food for the event. Coolers and bags of food are easily loaded and unloaded while standing on the ramp beside the plane.
______________________
Steve Eberhart, W9JUQ
3EV - Evansville, IN
Where is Steve and the Sky Terrier?
RV-7A Slider, O-360 A1A, Catto 3 blade, 2 screen Garmin G3X Classic, GTN 650, Bionics APRS. FLYING since June 24, 2009
EAA Chapter 21
Old 07-28-2017, 11:46 AM
Lars Lars is offline
I have the Meske tip-up slider mod on mine. Hugely improves luggage access. Rather than rooting for one over the other, I'd say pick which ever design you like and do it. The access improvement is worth it.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
500 hours as of September 30, 2017
Old 07-28-2017, 06:06 PM
Jpm757 Jpm757 is offline
I just finished installing supertracks as part of a new build, simple and sturdy. If you are still in the build process you can save a few bucks and delete the track extension from the kit and order an RV8 spine track from Vans then you won't have to splice the track.
Jake
Jake Mahoney
RV6 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017
2018 dues paid.
Old 07-28-2017, 06:11 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
I have the slider tip up mod now. Talked with Fly Boys at OSH. Thinking now about converting to the super track mod. My current slider tip up works good but I do believe the super track will work better for my needs. Will keep you updated if I make the swirch.
RVBYSDI
Steve
RV9A
Live Long And Prosper! 🖖🏻
Old 07-28-2017, 06:38 PM
dougmattson dougmattson is online now
I put the 14 mod in first and then hit the canopy getting in and out. The super track fixed that.
9A flying
Old 07-28-2017, 08:23 PM
RV7ator RV7ator is offline
Forget the kits.
Notch the slider track, exactly the width of the block. Slightly taper leads on the notch edges and block edges.
V-notch the rails 11.5" back from the roll bar, about a 60 degree included angle.
Drill out skirt brace/tube rivet. Make a prop rod. Drill a hole in the nylon pin block.
Takes about 1 1/2 hours depending on if the parts are installed or not, plus time to study the monkey motion and get comfortable with positioning the cuts.
Being able to tip the slider for baggage access convinced a friend a -14 was not for him with its difficult baggage access.
John Siebold
Old 07-28-2017, 08:33 PM
9GT's Avatar
9GT 9GT is offline
Originally Posted by RV7ator View Post
Forget the kits.
Notch the slider track, exactly the width of the block. Slightly taper leads on the notch edges.
Drill out a rivet in the skirt. Make a prop rod. Drill a hole in the nylon pin block.
John Siebold
John. This sounds very interesting and I am trying to visualize the process in my head. Do you have a build log or any photos available for this mod? Thanks. Dave
David C.
Howell, MI
RV-9A: Under Construction
"Donor Exempt" but donated through Dec. 2018
Old 07-28-2017, 08:48 PM
RVbySDI's Avatar
Forget the kits.
John Siebold
+1 for pics. How does the front of the canopy pivot on the stock rollers?
RVBYSDI
Steve
RV9A
Old 07-29-2017, 10:04 AM
carlrai's Avatar
carlrai carlrai is offline
Default +2 for the photos/drawing
This really sounds like a good alternative to a pricey kit. Have been putting off buying the Super Tracks and this may be the solution I've been looking for.
Carl Raichle
Lutz, FL
RV-9A N194CR
Based at KZPH
AA4SR
