Old 07-05-2017, 09:28 AM
BoilermakerRV's Avatar
BoilermakerRV BoilermakerRV is offline
Default WD-657 Installation
Took advantage pf the long weekend and got a lot done on the RV. Started on the external step installation on Tuesday. I really like where my steps are sitting at the moment. The hole in the skin isnt overly large and the flange of the step is nearly flush with the skin. What little gap remains can be easily closed out with a little finger pressure.
The only catch is, the current location only picks up three of the four specified fastener locations common to the F-724 rib. I would have to move the step up about 5/8 to capture all four fasteners as shown in the plans. This would make my cutout much larger (and possibly even start to show on the bottom). Im wondering if I can get by with just three of the four.
In the picture below (Left side step, forward edge to left of the photo), the crosses are the new fasteners laid out per the plans. The dots are the approximate location of the F-724 fasteners.
Michael
Danville, IN
RV-7A Fuselage
N317PU Reserved
2017 Dues paid (July 2017)
Old 07-05-2017, 09:47 AM
wirejock's Avatar
wirejock wirejock is offline
Default Step
Mine is the same but I measured and added one hole above and below.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 08-31-2017, 10:09 AM
Default From the Mothership
Just for the record, here was the response form Van's...
The exact number/location of rivets is not that important. See pic on our 7A here you can see they went between the skin rivets.
Michael
Danville, IN
RV-7A Fuselage
N317PU Reserved
